Component: Accel / Gyro / Mag 9-Axis (LSM9DS1) (Movement Orientation)
(Redirected from Component: ID 20699a0c 0925 40c4 8aa1 35f294e225e6)
Version | 1.1 |
Category | Movement Orientation |
- 1 Accel / Gyro / Mag 9-Axis (LSM9DS1) component
- 2 Detailed description
- 3 Examples
- 4 Macro reference
- 4.1 CollectXYZData
- 4.2 Initialise
- 4.3 ReadTemperature
- 4.4 Read_Bearing
- 4.5 Read_N_Registers
- 4.6 Read_Register
- 4.7 SetAddress
- 4.8 SimReset1G
- 4.9 SimSetAccelerometer
- 4.10 SimSetCompass
- 4.11 SimSetGyro
- 4.12 SimSetTemperature
- 4.13 UpdateAccelerometerData
- 4.14 UpdateCompassData
- 4.15 UpdateGyroData
- 4.16 Write_N_Registers
- 4.17 Write_Register
- 5 Property reference
- 6 Component Source Code
LSM9DS1 Combined 9-Axis Accelerometer, Gyroscope and Magnetometer sensors Useful for working out orientation data such as Pitch, Yaw and Roll.
CollectXYZData
Initialise | |
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
- BYTE | Return |
ReadTemperature
ReadTemperature | |
Reads the temperature from the sensor and returns the value as an integer. | |
- INT | Return |
Read_Bearing
Read_N_Registers
Read_N_Registers | |
Reads a set of data values from sequential registers on the accelerometer | |
- BYTE | Start_Reg |
- BYTE | Num_Regs |
- BYTE | Data |
- VOID | Return |
Read_Register
Read_Register | |
Reads a value from a register on the accelerometer. | |
- BYTE | Reg |
- BYTE | Return |
SetAddress
SetAddress | |
- BOOL | Address |
0=Accelerometer, 1=Magnetometer | |
- VOID | Return |
SimReset1G
SimReset1G | |
- VOID | Return |
SimSetAccelerometer
SimSetAccelerometer | |
Allows the XYZ slider values to be set via the simulation | |
- INT | X |
- INT | Y |
- INT | Z |
- VOID | Return |
SimSetCompass
SimSetCompass | |
- INT | X |
- INT | Y |
- INT | Z |
- VOID | Return |
SimSetGyro
SimSetGyro | |
- INT | X |
- INT | Y |
- INT | Z |
- VOID | Return |
SimSetTemperature
SimSetTemperature | |
- INT | Temp |
- VOID | Return |
UpdateAccelerometerData | |
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
- BYTE | Return |
UpdateCompassData
UpdateCompassData | |
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
- BYTE | Return |
UpdateGyroData
UpdateGyroData | |
Reads from the gyroscope and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
- BYTE | Return |
Write_N_Registers
Write_N_Registers | |
Writes a set of data values to a sequential registers on the accelerometer | |
- BYTE | Num_Regs |
- STRING | Data |
- VOID | Return |
Write_Register
Write_Register | |
Writes a data value to a specific register on the accelerometer | |
- BYTE | Reg |
- BYTE | Data |
- BYTE | Return |
Please click here to download the component source project: FC_Comp_Source_AccelMagGyro_LSM9DS1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AccelMagGyro_LSM9DS1.fcfx
