Component: Joystick (Sparkfun Quiic) 2D (Analog Input)
(Redirected from Component: ID 94c78e1b f580 4105 a223 7e40b75d134c)
Version | 1.0 |
Category | Analog Input |
Joystick (Sparkfun Quiic) 2D component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Please click here to download the component source project: FC_Comp_Source_Sparkfun_Quiic_Joystick_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Sparkfun_Quiic_Joystick_2dgi.fcfx
ChangeI2CAddress
CheckButton
CheckButton | |
Checks to see if the button has been pressed since the last read of CheckButton or ReadButton. | |
- BOOL | Return |
Initialise | |
Initialises the I2C bus ready for communications with the module. | |
- VOID | Return |
ReadAxis
ReadAxis | |
Reads a single axis of the joystick and returns as a signed integer value. | |
- BYTE | Axis |
Range 0-1 Where 0=X, 1=Y | |
- BOOL | Type |
0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023) | |
- INT | Return |
ReadButton
ReadButton | |
Checks to see if the button is currently pressed | |
- BOOL | Return |
SimMoveThumbStick
SimMoveThumbStick | |
- FLOAT | X |
- FLOAT | Y |
- HANDLE | Component |
- VOID | Return |
WriteRegister
WriteRegister | |
- BYTE | Address |
- BYTE | Value |
- BOOL | Return |
