Component: Temperature (DS18S20) (Environmental)
Author | MatrixTSL |
Version | 1.0 |
Category | Environmental |
Temperature (DS18S20) component
A rugged temperature sensor allowing one or more sensors to be addressed and read. Capable of reading temperatures from -55 to +125 degrees C. Requires a One Wire component to perform the bus operations.
Please click here to download the component source project: FC_Comp_Source_Temperature_DS18S20.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Temperature_DS18S20.fcfx
This example shows how to connect the DS18S20 component to the OneWire component and either select a specific device on the bus or scan through the devices on the bus collecting the temperature readings.
The temperature and serial number is output using a UART connection as is onboard a Arduino or ESP32 device.
AddressNextDevice
AddressNextDevice | |
Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro. | |
- VOID | Return |
AddressSpecificDevice
GetSerialString
GetSerialString | |
Gets the Serial String for the current addressed device. | |
- STRING | Return |
GetTemperature
GetTemperature | |
Reads the temperature from the last sample on the selected device. The selected device is set using the AddressNext or AddressSpecific macros. | |
- FLOAT | Return |
Initialise | |
Configures each matching sensor on the bus with the specified conversion bits. | |
- VOID | Return |
SampleAddressedDevice
SampleAllDevices
