Component: Pulse Oximeter (Max30100) (Environmental)
(Redirected from Component: ID caa29480 5f50 4c3b 8dac 22cfb8e36999)
Version | 1.0 |
Category | Environmental |
Pulse Oximeter (Max30100) component
Sensor designed to monitor heart rate and pulse omimetry. Connected using an I2C bus.
Please click here to download the component source project: FC_Comp_Source_Max30100_Pulse_Oximeter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Max30100_Pulse_Oximeter.fcfx
ReadIR
ReadIR | |
Returns one of the FIFO IR readings from the last update | |
- UINT | Return |
ReadRed
ReadRed | |
Returns one of the FIFO Red readings from the last update | |
- UINT | Return |
SetHighResModeEnabled
SetHighResModeEnabled | |
- BYTE | Enabled |
- VOID | Return |
SetLEDsCurrent
SetLEDsCurrent | |
- BYTE | IR |
Range: 0-15 / 0=0mA, 1=4mA, .., 14=46mA, 15=50mA | |
- BYTE | Red |
- VOID | Return |
SetLEDsPulseWidth
SetLEDsPulseWidth | |
- BYTE | PulseWidth |
- VOID | Return |
SetSamplingRate
SetSamplingRate | |
- BYTE | SampleRate |
Range: 0-7 / 0=50Hz, 1=100Hz, .., 6=800Hz, 7=1000Hz | |
- VOID | Return |
Update
Update | |
Reads the sensor FIFO buffer and stores the readings into local RAM. Returns the number of samples read. | |
- BYTE | Return |
