2.4 inch ILI9341 display advice
WingNut
Has thanked: 33 times
Been thanked: 23 times
Post by WingNut »
Got myself a few of these from AZ delivery https://www.amazon.co.uk/AZDelivery-XPT ... merReviews
There are 5 pins to deal with data/clock etc in serial mode but the fc module uses a 6th Dataport_low defaulting to C.0 Where does it get connected?
Its the same layout as below http://www.lcdwiki.com/2.4inch_Arduino_Display
Pointers much appreciated
ili9341 az delivery uno v pic test.fcfx
(10.1 KiB) Downloaded 94 times
Has thanked: 439 times
Been thanked: 602 times
Re: 2.4 inch ILI9341 display advice
The information you linked to states Module Interface 8-bit parallel interface
I don't think you will be able to use these displays in SPI mode.
How about this for the parrallel connections..
If you also want to use the SD card socket then you can link the SD card / FAT component to the four SD_ connections.
I'm not seeing any touch connections which is odd as it says it has touch capability and shows a stylus.
WingNut
Post by WingNut »
Thanks Ben. I did think I would need to use a full port for the data. Kind of limits the capabilities of any circuit i put it in but should work pretty fast. I'll give it a go over the next couple of days and get back
