PIC18 extended instruction set was enabled but is not supported by this compiler
Posted: Tue Mar 26, 2024 11:14 am
by lowo
ATS-5S18F46K22.c:37:45: error: (1504) the PIC18 extended instruction set was enabled but is not supported by this compiler
I have the license installed but still cant get the PIC18F46K22 to compile. I am getting the above error.
Re: PIC18 extended instruction set was enabled but is not supported by this compiler
Posted: Tue Mar 26, 2024 12:10 pm
Select
Build >
Project Optiuons...
Change
Extended Instruction Set Enable bit to
Disabled
Are you sure you want
Single-Supply ICSP enable bit on
Enabled
If via ISCP and the programmer has a VPP connection, then you will need to change it to Disabled as well.
Also, disable your
Watchdog Timer Enable bits unless you want it enabled?
If you do you will need to have Auto clear watchdog ticked under
Other Options
The First thig I would recommend is create a
one sec flash timer to check hardware is working as expected.
I have moved this topic as it has nothing to do with
PIC compiler toolchain is not installed
Posted: Tue Mar 26, 2024 12:11 pm
by Steve-Matrix
lowo wrote: ↑Tue Mar 26, 2024 11:14 am
The "Extended Instruction Set" bit is set in the config word for that device. You will need to set it to "disabled" in the "configure" sections of the Project Options screen.
Posted: Wed Mar 27, 2024 4:53 pm
by lowo
100% Appreciation. Thankyou very much. It worked.
