RTC clock setting
Posted: Thu Dec 02, 2021 9:28 pm
Help!
I can't figure out why the clock won't set in the first file yet I can get it to set in the simpler second file. Its a very meesy file I know but I'm still a novice at flowcode. Also it is really slow to run. It reads bytes from a file CFG_DAT.DAT. The first bytes are basically a value to set a sample rate - works fine. I've it set to 1 second but it takes about 4 minutes to run through a 5 stage loop. My main concern is not being able to set the clock on the rtc module yet I can produce a basic clock with what I see as the same procedure
Probably dead obvious but I jst cant see what the problem is
N
N
