PIC 12F629 gpio internal pull-up/down settings
- Has thanked: 1 time
- Been thanked: 1 time
Hi, I have a difficulty to set the code of gpio internal pull-up/down settings. Anyone can teach me how to set the code? Thank a lot!
- Has thanked: 438 times
- Been thanked: 602 times
Re: PIC 12F629 gpio internal pull-up/down settings
The PIC12F629 only has internal pull up resistors but these can be enabled as follows using a C icon.
OPTION_REG = OPTION_REG & 0x7F; //Clear GPPU bit enabling pull ups
WPU = 0x11; //Enable Pullup on GPIO0 & GPIO4
Is it correct? The internal pull up resistors of IOPort 4 is still disable.BenR wrote: ↑Thu Jun 16, 2022 9:41 amHello,
OPTION_REG = OPTION_REG & 0x7F; //Clear GPPU bit enabling pull ups WPU = 0x11; //Enable Pullup on GPIO0 & GPIO4
Thanks.
You have the C code in between the /* and */ symbols, these are comment blocks and need removing otherwise the code is effectively commented out.
