EEPROM_FLOAT PIC16F1939
Posted: Sun Mar 24, 2024 3:14 am
Hello, I would appreciate some help;
I have had some free time and I have been playing with Flowcode 10 and its components, which I see have added features that they did not have in previous versions, some features such as the 16x2 display, EEPROM, which added writing and reading in float, long, INT I made a small flowchart that reads a FLOAT number and then writes it to the EEPROM memory and reads it when required; add 2 switches, one reads a number with 6 decimal places and the second switch reads another number with 6 decimal places also but negative; I have a GPS that I want to improve and record locations at different times, to later check the places visited, but after recording the numbers in the EEPROM to later read them, one reads the recorded number, but the second changes to a different number; I send the flowchart. I would appreciate if you can see it and help me; I assume that using variables in FLOAT the number is read directly and with that same variable it is recorded in the EEPROM, I looked for an example, but in FLOAT I found nothing.
I appreciate any help in advance.
Enrique
Enrique
