Hi everyone,
Does FC support Internal Can BUS on ESP32? The FC component shows... but does it work?
Cheers,
R
ESP32 Internal CAN Bus Support
- Has thanked: 26 times
- Been thanked: 11 times
- Has thanked: 438 times
- Been thanked: 602 times
Re: ESP32 Internal CAN Bus Support
Yes it should be working, I'm not sure if it's been tested but there is certainly code there to drive the internal CAN peripheral.
Many thanks Ben for this,
Will give a try to see if the interface works at all... Do you think RX CAN Interrupt can be implemented in Flowcode?
Thanks,
R
Thanks,
R
