Page 1 of 4
PIC24FJ512GA606 download error!
Posted: Tue Dec 28, 2021 4:06 am
by seokgi
I have a question.
I'm working on a project using PIC24FJ512GA606.
When I select the project option and compile and download it, an error that the device is not recognized appears.
And when I look at the project options again, I see the other chip selected. How to solve it?
Please help.
thank you.
Re: PIC24FJ512GA606 compile error!
Posted: Tue Dec 28, 2021 8:56 am
by FITech
Looking at the PLL Block for the chip, max system CLK is 32MHz.
You need to lookup the datasheet to see what Configuration Bits and necessary registers to set.
Posted: Tue Dec 28, 2021 11:39 am
by seokgi
Thank you for answer.
But the key is that the compiled data is not downloaded to the mcu.
Re: PIC24FJ512GA606 download error!
Posted: Tue Dec 28, 2021 11:52 am
by kersing
The PICkit detects an DSPIC33FJ32MC302, so either you are using the wrong chip or you need to check your hardware setup.
By the way, next time you post compiler output please go to the ….msg.txt file in your flowchart folder and copy-and-paste the text in the file, not a screenshot for easier reading for us.
Posted: Tue Dec 28, 2021 7:37 pm
by seokgi
I post the message file.
Posted: Tue Dec 28, 2021 8:14 pm
by kersing
What is your hardware? What is connected to what?
Posted: Tue Dec 28, 2021 8:26 pm
by seokgi
I'm connected PICKIT3 to PIC24FJ512GA606.
Posted: Tue Dec 28, 2021 9:22 pm
by kersing
A bit more information would not hurt. How did you connect the two? Which pin to which pin? What else is connected?
Posted: Tue Dec 28, 2021 11:38 pm
by seokgi
Post my drawings.
Posted: Wed Dec 29, 2021 10:31 am
by seokgi
MPLAB IPE downloads normally.
Please make it work in FC9.
