Page 2 of 7
Re: HB100 radar!
Posted: Fri Sep 17, 2021 8:57 pm
by jgu1
Ok Martin, but still no in display. Also not with signal generator, only 0
Re: HB100 radar!
Posted: Fri Sep 17, 2021 9:20 pm
I have just downloaded the flowchart I have posted & the Timer 2 properties looks like they have changed.
These should be the correct settings:
- Timer2 interrupt settings.png (22.95 KiB) Viewed 3818 times
Re: HB100 radar!
Posted: Sat Sep 18, 2021 7:03 am
by jgu1
Thank´s Martin. I see now, to fast the old timer. I test later today /afternoon and you hear. I have send you a PM
Re: HB100 radar!
Posted: Sat Sep 18, 2021 1:12 pm
Hi, Jorgen.
If it still does not work, can you try injecting a CMOS compatible frequency directly into pin 11.
Make sure there is a good connection between GNDs of CMOS signal and MCU.
I have just tested on a 16F18877 and that is showing the correct frequency.
Thank you for the PM, I have sent you a reply.
I hope it does work for you.
Re: HB100 radar!
Posted: Sat Sep 18, 2021 4:26 pm
by jgu1
Hi again!
Strange it work for you and not for me.
I have change the timer2 . I try send frequency from 0 to 100hz 5V from my generator in on pin 11, Check my hardware many time, but no luck.
I suppose the input should have a very high impedance, so if I touch the input it should at least count something?
will you please check I have done it correct. Any idea Martin.
Re: HB100 radar!
Posted: Sat Sep 18, 2021 4:43 pm
Flowchart looks correct.
Do you have a scope or logic analyser you can connect directly between pin11 and GND?
Re: HB100 radar!
Posted: Sat Sep 18, 2021 4:49 pm
by jgu1
Yes, I have a scope (old analog). And when I look at this I have fine square 4,5V signal on the input.
Re: HB100 radar!
Posted: Sat Sep 18, 2021 5:18 pm
by jgu1
I have no try to add a flasher. at upstart I see the flash one time and after that it stop and the display is "running" with zero?
I seemed if I add something it stop. I also try to change the device. Could it be a bug with the interrupt in 16f876? I try to shift to a 16f88 tomorrow
Re: HB100 radar!
Posted: Tue Sep 21, 2021 7:49 pm
by jgu1
Hi Martin!
Finally get some more time to play
The 16f876 I see data in the display, but nothing count when I trig the input 4,7V square wave.
Now I perform some test with the Pic16f1937. To be sure the program is running I let B7 flash 5 time before continue, but nothing in the display.
When I test with my scope I don´t see anything on the display pin on the 1937, so no data.
Ok I will buy a 16F18877 as yours but anyway I suppose the 876 and the 1937 also should be able to do the same as your device?
Thank´s in advance.
Br Jorgen
Re: HB100 radar!
Posted: Tue Sep 21, 2021 7:54 pm
Hi Jorgen,
I have a 16F1937 so I can make sure it works with that target device.
I will get back to you after testing is complete.
