It is possible to add a transmission module GSM based on the NEOWAY M590. I have a kit based on it and on the development board in addition to the usual vcc and 5v there are pins with the names I T V K G
If it was possible...
Thank you.
selozerouno.
Module GSM M590 kit for Arduino and other chip.....
- Has thanked: 2 times
- Been thanked: 2 times
- Has thanked: 439 times
- Been thanked: 602 times
Re: Module GSM M590 kit for Arduino and other chip.....
It looks like this module should work as is with our existing GSM component.
Though I'm not sure about the IO markings on the board you have, the chip datasheet seems to have the standard TX/RX UART interface.
Do you have a link to the board you have so we can see if there is any additional information on it?
