ADC on 16F18426
Posted: Mon Sep 06, 2021 7:43 pm
by Marc-Lepage-AIF
Hello BEN, Thank's for your help and the update of the library. But sorry the problem is still there , ADC is not implemented ...or maybe I do something wrong...? My prog must take the analog signal on AN2 and send result on com via C0. It's not coming from the electonic as a friend of mine has made a C prog and it works. But i do not want to use any outside prog , all must be done with Flowcode. Could you please have a second look at my problem ? Thank's . Marc
Re: ADC on 16F18426
Posted: Tue Sep 07, 2021 6:36 am
by p.erasmus
Are you sure the micro is running (How do you know that )
Did you try just to write a dummy value to the UART and see if your UART coms are working example, write 3,42V ?
also from your FC chart you use a ADC clock of FOSC/28 thats maybe a bit slow I would use 16.
Re: ADC on 16F18426
Posted: Tue Sep 07, 2021 11:12 am
by BenR
These two settings in your confguration look incorrect, can you check these settings,
- Config.jpg (47.28 KiB) Viewed 2232 times
What values are you getting out the UART? If your not getting anything then maybe worth doing a one second flash test.
https://www.flowcode.co.uk/wiki/index.p ... ED_flasher
Re: ADC on 16F18426
Posted: Tue Sep 07, 2021 10:21 pm
by Marc-Lepage-AIF
Hi Ben , Hi erasmus,
Thank's both ...find here under the correct setting...
