Page 5 of 5
Re: MAX7219 DOT MATRIX 8 x 8 Pixels
Posted: Mon Dec 13, 2021 6:26 pm
by Sergejs
With any MCU I can not see any info on dashboard to select displays count and other parameters.
Posted: Mon Dec 13, 2021 8:57 pm
by mnfisher
Try clicking on View -> Component Properties. You should be able to select the Max7219 component in the properties box that appears
- FC__00076.jpg (42.45 KiB) Viewed 2171 times
Posted: Mon Dec 13, 2021 9:13 pm
by mnfisher
Looking at my post I see that the SPI chip select pin isn't appearing.. I'm sure I put it to top level ?
Will re-export and try again...
Posted: Tue Dec 14, 2021 2:33 am
by Sergejs
That's the problem, I do not see anything when I open Component Properties.
Posted: Tue Dec 14, 2021 7:51 am
by mnfisher
That means the component isn't being seen by Flowcode.
Check that you downloaded the file to the correct folder.
Try adding the component to your project again - components search.
