Hi FCUsers ! I have 2 PC´s with FC9.
In one of them I can see the two TABS ("Uart-ComPort1" and "User Input") when running, and the simulation goes ok.
But in the second PC, even with the same code on both machines, the "User Input" tab always desappears when RUN (F5)
What could be wrong with this PC ?
Thanks for any tips.
Console User Input TAB desappering !
- Has thanked: 18 times
- Been thanked: 2 times
- Console before RUN.PNG (157.35 KiB) Viewed 1494 times
- Console after RUN.PNG (182.52 KiB) Viewed 1494 times
- Has thanked: 278 times
- Been thanked: 397 times
Re: Console User Input TAB desappering !
Are both versions up to date (both running latest versions)?
A few minor Console issues were reported in early releases, that were subsequently resolved in the updates.
Hope this helps,
Hope this helps,
Hi chip. Yes, both FC9 are updated. This is the fact that confuse me. But I´ll read the past issues with Console. It´s also a good idea. Thanks.
- Has thanked: 435 times
- Been thanked: 598 times
As well as the flowcode core application updates have you gone to the Help -> Library updates to make sure you have the latest component updates. Might be worth changing the files in use drop down to full database and this will update everything.
If you're still having problems after this then let us know and I'll investigate for you.
Hi ! Trying to clarify the issue with my first two computers, I took a third Win10 PC (my businness notebook) and installed a new copy of FC9 from scratch, with respectivelly updated files and components.
Just after loading the “ConsoleDemo.fcfx” code (and all successive re-loads of it), I really could see the two static TABS (“Uart-ComPort1” and “User Input”) on Console.
But for my surprise, always when RUN (F5) the “User Input” tab are still disapeering, althought “Uart-ComPort1” tab remains.
My impression is that Console only runs satisfactorily on my FIRST PC, that haven´t updated the FC9 CORE SYSTEM. The two others with updated cores, are not working for me.
- before RUN.jpg (121.49 KiB) Viewed 1437 times
- After RUN.jpg (120.61 KiB) Viewed 1437 times
Many thanks for confirming and letting us know, hopefully now fixed for you via the Help -> Library updates.
Console User Input TAB appering now ... Thanks !!
- Console working.jpg (116.03 KiB) Viewed 1420 times
