dht22 update with possible problem
Posted: Sat Feb 10, 2024 3:27 pm
Hi, after updating this sensor's library I started having problems in a project I'm developing and where I'm using this dht22.
I went to the component library and changed it to the previous version and then it started working correctly again.
I hope to help someone with the same problem and also the programmer find the solution.
in the return variable of the "samplesensor" macro I get the number: 79.
I don't know if it helps anything.....
