Function Zero() doesn`t work.
It works in FC8.2 but in 9.2 doesn't work
HX711 zero
- Been thanked: 2 times
- Has thanked: 435 times
- Been thanked: 598 times
Re: HX711 zero
Can you attach a simple program and I will investigate for you. We use the HX711 on some of our in house products so it's strange it's not zeroing for you.
Re: HX711 zero
here is the code, and the results from UART.
Even if I put Macro "zero" in loop < while > then I get similar results like attached.
Thank you for help in advance.
BR,
BR,
- HX711_ToTest.fcfx
- (10.92 KiB) Downloaded 113 times
- output5.PNG (76.06 KiB) Viewed 2381 times
Re: HX711 zero
Are you using the latest updates via the Help -> Library Updates window?
I've had a look through the HX711 code and it looks like the zeroing should be working fine. I'll run some tests here to double check.
Edit, I may have just spotted something, pushing it to the update system now.
Re: HX711 zero
it works OK! thank you for your great job!
I hope my topic related to BMP280 will be also solved soon
Best Regards,
Best Regards,
