Have been crazy busy for the last few weeks so have not been in to check messages. I will go update shortly and let you know what I find
gLCD 7789 & SPI component clash on ESP32
- Has thanked: 40 times
- Been thanked: 11 times
Re: gLCD 7789 & SPI component clash on ESP32
I got time to test the system and there seems to be a problem now that I have updated the components the program wont compile I have not changed anything other then update the components and I get the following error message.
- Has thanked: 438 times
- Been thanked: 602 times
I can't seem to replicate this one. I'll keep looking.
Can you confirm if it's still a problem with the latest updates? You might need to do a full database update to get all the latest DSP related bits.
I just did a full update but problem still there I'm going to PM you the program and see if you can replicate problem
Hi Guys
I still have not been able to sort the compiling error out
Really not sure how to go forward I have done all the updates with no luck.
- Has thanked: 167 times
- Been thanked: 277 times
The error location has changed for some reason. Your original one was:
...but now it is this:
It looks to be the same error, but is now in another part of the code. Did something change in your project to cause this?
../main/esp-project.c: In function 'FCD_0e811_DSPOutput1__GetFloat':
../main/esp-project.c:975:29: error: implicit declaration of function 'DSPBuff_0_Get'; did you mean 'DSPBuff_2_Get'? [-Werror=implicit-function-declaration]
#define DSPOutput1_Ref1_Get DSPBuff_0_Get
../main/esp-project.c: In function 'FCD_0db01_DSPPIDControl1__Process':
../main/esp-project.c:942:33: error: implicit declaration of function 'DSPBuff_0_Get'; did you mean 'DSPBuff_2_Get'? [-Werror=implicit-function-declaration]
#define DSPPIDControl1_Ref1_Get DSPBuff_0_Get
