Page 2 of 3
Re: gLCD 7789 & SPI component clash on ESP32
Posted: Tue Nov 23, 2021 11:32 am
by jollybv
Have been crazy busy for the last few weeks so have not been in to check messages. I will go update shortly and let you know what I find
Posted: Thu Nov 25, 2021 2:08 pm
by jollybv
I got time to test the system and there seems to be a problem now that I have updated the components the program wont compile I have not changed anything other then update the components and I get the following error message.
- error message.png (72.14 KiB) Viewed 3613 times
Posted: Thu Nov 25, 2021 2:42 pm
by LeighM
Please could you attach the project msg.txt file?
That will help much better than a partial screen shot
Posted: Fri Nov 26, 2021 5:49 am
by jollybv
Hi Leigh
Here is the Compiler message
Posted: Fri Nov 26, 2021 8:55 am
by LeighM
Thanks.
Looks like there is an issue in DSPOutput::GetFloat()
I'll leave it for Ben to look at
Posted: Fri Nov 26, 2021 2:47 pm
by BenR
I can't seem to replicate this one. I'll keep looking.
Can you confirm if it's still a problem with the latest updates? You might need to do a full database update to get all the latest DSP related bits.
Posted: Sat Nov 27, 2021 4:55 am
by jollybv
I just did a full update but problem still there I'm going to PM you the program and see if you can replicate problem
Posted: Thu Dec 09, 2021 2:32 pm
by jollybv
Did you get a chance to look at the program I sent you in a PM as to why it will not compile?
Posted: Tue Jan 18, 2022 12:13 pm
by jollybv
Hi Guys
I still have not been able to sort the compiling error out
Really not sure how to go forward I have done all the updates with no luck.
Posted: Tue Jan 18, 2022 1:14 pm
by Steve-Matrix
The error location has changed for some reason. Your original one was:
../main/esp-project.c: In function 'FCD_0e811_DSPOutput1__GetFloat':
../main/esp-project.c:975:29: error: implicit declaration of function 'DSPBuff_0_Get'; did you mean 'DSPBuff_2_Get'? [-Werror=implicit-function-declaration]
#define DSPOutput1_Ref1_Get DSPBuff_0_Get
...but now it is this:
../main/esp-project.c: In function 'FCD_0db01_DSPPIDControl1__Process':
../main/esp-project.c:942:33: error: implicit declaration of function 'DSPBuff_0_Get'; did you mean 'DSPBuff_2_Get'? [-Werror=implicit-function-declaration]
#define DSPPIDControl1_Ref1_Get DSPBuff_0_Get
It looks to be the same error, but is now in another part of the code. Did something change in your project to cause this?
