Page 1 of 2
ESP32
Posted: Thu Oct 28, 2021 11:19 pm
by Alan_37
Hi, I have been playing with Esp32, and if I am not doing something wrong the following are bugs.
1, The quad encoder Post Scaler 1:4 does not work it always returns 4 steps at a time.
2, If putting an OR statement in a loop will not compile to hex.
3, for some strange reason sometimes ( not always) when using local variables, will cause failure to compile ( then use global and compile ok)
4, MQTT read timeout does not work Setting it 50ms it stops there until a message is received after 1
a minute or so if no message is received will exit and will not work again.
Re: ESP32
Posted: Fri Oct 29, 2021 7:45 am
by LeighM
Thanks for the post.
Would it be possible for you to give us some examples?
These look like very specific scenarios that we might not have enough information to replicate.
For example, OR is a bitwise OR, so might not be suitable for your situation.
Re: ESP32
Posted: Fri Oct 29, 2021 3:44 pm
by Alan_37
HI ,
So the loop bug example -> Loop until: var1 = 100 OR var2 = 200 .
As for the MQTT read timeout, this is very important cos it stops all the code from executing
I was able to work around the problem of it stop receiving by doing a disconnect and connecting again
every time I run the Read.
but it still hangs there waiting.
Re: ESP32
Posted: Fri Oct 29, 2021 3:58 pm
by LeighM
Try this instead
(var1 = 100) || (var2 = 200)
I'll have a chat with Ben re the IOT bug on Monday, it's his wrap on my MQTT Client.
Re: ESP32
Posted: Mon Nov 01, 2021 2:09 pm
by Alan_37
Thanks, looking forward for the fix .
Re: ESP32
Posted: Mon Nov 01, 2021 2:43 pm
by BenR
Does this work any better for you?
IoTMadeEasy.fcfx
(25.17 KiB) Downloaded 574 times
Re: ESP32
Posted: Mon Nov 01, 2021 7:48 pm
by Alan_37
Hi Ben, Thanks for your reply
No, it does not work, the led does not blink because the read timeout is not working
and the esp is stuck waiting for the MQTT message.
After some time led starts to blink but then it does not receive MQTT messages anymore
then it connects again and stops there waiting again.
I can still ping the esp and my MQTT server is also pingable.
Re: ESP32
Posted: Tue Nov 02, 2021 3:16 pm
by Alan_37
I have a question,
Does the free ESP32 chip pack have limited support or offered as is ?
Re: ESP32
Posted: Thu Nov 04, 2021 9:51 am
by LeighM
Could you please try the attached updated file, to go into C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP
Re: ESP32
Posted: Fri Nov 05, 2021 6:52 am
by Alan_37
Hi LeighM, Thanks for your reply
I have replaced the file now the read timeout seems to be working but
now the ESP is not able to receive or send any messages from/to the MQTT server .
