Page 1 of 2
DSP Filter update
Posted: Fri Nov 12, 2021 9:59 am
by stefan.erni
I suspect that my DSP filters will no longer work with the last update.
First I had to redraw the connection to the digital output. But then the filters deliver a wrong signal,
as if the maximum level would be. I suspect a problem with the signed long from input to filter to output
- Filter_2021-11-12_10-19-45.png (139.65 KiB) Viewed 3313 times
Re: DSP Filter update
Posted: Fri Nov 12, 2021 12:03 pm
by BenR
Hmm ok thanks I'll look into this one for you and see if I can replicate.
Posted: Thu Nov 18, 2021 11:36 am
by stefan.erni
Just a DSPOuput version 6 problem?
If I go back from version 6 to version 3 the DSPOuput it's working again
There is no version 4 or version 5
- working_not_2021-11-18_11-24-54.png (9.62 KiB) Viewed 3239 times
- working_2021-11-18_11-34-44.png (8.44 KiB) Viewed 3239 times
Posted: Thu Nov 18, 2021 11:59 am
by BenR
Hmm ok thanks I'll have a look for you.
Edit I've pushed a new version of the component for you. There is a new property called auto scale, the old v3 version would have had this enabled, I've added it as a property to allow the user more control over what's going on.
Posted: Thu Nov 18, 2021 2:24 pm
by stefan.erni
Ok. I will try that.
With the update it deleted again the connection to the filter
But there is a new problem:
connect the filter output (again) is not possible from the menue.
- no_choice_2021-11-18_15-06-16.png (21.58 KiB) Viewed 3231 times
Posted: Fri Nov 19, 2021 4:00 pm
by BenR
Thanks Stefan,
I've updated the filter component so it should be available in the list now.
Posted: Fri Nov 19, 2021 4:28 pm
by stefan.erni
Yes it's better......but all this connection was deleted and I can not found it in the menue to connect it again.
- DSP_2021-11-19_17-22-48.png (133.14 KiB) Viewed 3217 times
Posted: Fri Nov 19, 2021 4:34 pm
by BenR
Thanks again,
Hopefully the math component is sorted for you now too.
Posted: Fri Nov 19, 2021 5:05 pm
by stefan.erni
It's not the Math, it's the DSPScale
Posted: Mon Nov 22, 2021 3:53 pm
by BenR
Hi Stefan,
Sorry not sure why I thought it was the math comp, scale now fixed for you too.
