How to know which modification are done on components?
lucibel
Has thanked: 29 times
Been thanked: 22 times
Post by lucibel »
How to know which modifications are done on components ?
Before to update it's important to know clearly because some of them can be critical.
How to get the history versions and modifications
component log file.jpg (28 KiB) Viewed 5232 times
Thx for your prompt reply
Seb
Has thanked: 435 times
Been thanked: 598 times
Re: How to know which modification are done on components?
Hi Seb,
Currently there is no real way of knowing without asking us to look back at he change history, we could maybe add something into the wiki on each component page but it would be a manual process and ideally you want the information as part of the update tool.
It's on the list as something to investigate for v10.
lucibel
Post by lucibel »
if can be implement on filename link who can open the log file will be very good.
component log file.jpg (23.77 KiB) Viewed 5218 times
click on included.c will open the log file.
Which modifications did you do on the Includes.C, CircularBuffer and COMPort ?
Seb
Includes.c - Now allows for up to 3 CAN channels instead of the previous limit of 2.
CircularBuffer - GetArray was not pointing to the sim version of the function and had an unused string return variable.
COMport - Nothing to report
lucibel
Post by lucibel »
Hello Ben,
What are the modifications done on the
ttgo fcdx.jpg (18.79 KiB) Viewed 5090 times
thx
Seb
Hello Seb,
We added an experimental microsecond option for the timer interrupts.
lucibel
Post by lucibel »
What are the modifications done on RTC_ESP32_NTP revision 4 ?
Seb
Has thanked: 506 times
Been thanked: 469 times
Hi Seb.
I believe that is covered within this topic.
lucibel
Post by lucibel »
Ben, could you send me the RTC_ESP32_NTP revision 3 please.
since install version 4 , compile failed!
Seb
LeighM
Has thanked: 69 times
Been thanked: 208 times
Post by LeighM »
Hi Seb,
It's easy to roll back, once you know how ;)
Then click "Download"
