Page 1 of 2
How to know which modification are done on components?
Posted: Tue Jan 18, 2022 7:22 am
by lucibel
How to know which modifications are done on components ?
Before to update it's important to know clearly because some of them can be critical.
How to get the history versions and modifications
- component log file.jpg (28 KiB) Viewed 5488 times
Thx for your prompt reply
Re: How to know which modification are done on components?
Posted: Tue Jan 18, 2022 10:11 am
by BenR
Hi Seb,
Currently there is no real way of knowing without asking us to look back at he change history, we could maybe add something into the wiki on each component page but it would be a manual process and ideally you want the information as part of the update tool.
It's on the list as something to investigate for v10.
Posted: Tue Jan 18, 2022 10:34 am
by lucibel
if can be implement on filename link who can open the log file will be very good.
- component log file.jpg (23.77 KiB) Viewed 5474 times
click on
included.c will open the log file.
Which modifications did you do on the Includes.C, CircularBuffer and COMPort ?
Posted: Wed Jan 19, 2022 9:41 am
by BenR
Includes.c - Now allows for up to 3 CAN channels instead of the previous limit of 2.
CircularBuffer - GetArray was not pointing to the sim version of the function and had an unused string return variable.
COMport - Nothing to report
Posted: Tue Feb 01, 2022 9:52 am
by lucibel
Hello Ben,
What are the modifications done on the
- ttgo fcdx.jpg (18.79 KiB) Viewed 5346 times
thx
Posted: Wed Feb 02, 2022 11:05 am
by BenR
Hello Seb,
We added an experimental microsecond option for the timer interrupts.
Posted: Wed Feb 09, 2022 6:52 am
by lucibel
What are the modifications done on RTC_ESP32_NTP revision 4 ?
Posted: Wed Feb 09, 2022 8:20 am
Hi Seb.
I believe that is covered within
this topic.
Posted: Wed Feb 09, 2022 1:45 pm
by lucibel
Ben, could you send me the RTC_ESP32_NTP revision 3 please.
since install version 4 , compile failed!
Posted: Wed Feb 09, 2022 1:52 pm
by LeighM
Hi Seb,
It's easy to roll back, once you know how
- rollback.jpg (38.83 KiB) Viewed 5237 times
Then click "Download"
