Page 1 of 2
App Developer connect to ESP32 S3 with USB
Posted: Thu Apr 11, 2024 2:16 pm
by stefan.erni
Hi to All
One more question. With purchased hardware with an ESP32-S3, I have to press the reset button for 5 seconds to flash the firmware.
Then press the reset button again.
The programme runs.
Now I want a connection with the USB C connector to the computer.
A serial device com15 and also an USB jtag/serial debug unit appear in the device manager of the computer.
but I can't make a connection with the App Developper with Com 15
and I don't have a pin for the interface in the firmware either.
Is this connection possible with USB component ?
- Snag_1460d0e.png (135.19 KiB) Viewed 1572 times
Re: App Developer connect to ESP32 S3 with USB
Posted: Thu Apr 11, 2024 2:38 pm
by Steve-Matrix
I think you will need to use the Serial Port component and not the USB component.
Posted: Thu Apr 11, 2024 3:45 pm
by stefan.erni
Hi Steve
I suspect it's not that simple.
The USB pins go directly to the ESP32 C3. So I can't use an Rx/TX pin. Many ESP32 boards have a USB driver that goes from the USB connector to the UART pin.
What about BLE Uart? Is BLE already possible to test?
Posted: Thu Apr 11, 2024 4:26 pm
by Steve-Matrix
Sorry, I'm not familiar with that device. You should be able to communicate to COM15 from a PC Developer app using a Serial Port component. But I don't know how you would access the same serial connection from within Embedded code in the device itself.
Posted: Fri Apr 12, 2024 10:12 am
by BenR
Please can you send us a link to the specific board you're using.
Looks for devices like this to do comms back to the PC would require a USB component. Might not be too hard thanks to the IDF so I'll get it on the list.
Posted: Fri Apr 12, 2024 12:23 pm
by stefan.erni
Hi ben
Link to the specific board:
https://docs.m5stack.com/en/core/AtomS3
Link to a shop:
https://www.digikey.ch/de/products/deta ... 3/17751546
Demo with display (working in SPI softwaremode)
- Snag_34e8e.png (469.82 KiB) Viewed 1543 times
Posted: Mon Apr 15, 2024 9:54 am
by BenR
That looks great, are you able to program the screen? Do we need a new component for it?
I've just bought myself one and also got a couple more M5 boards. Unfortunatley they look like they might take a while to get here.
- Order.jpg (56.45 KiB) Viewed 1520 times
Posted: Wed Apr 17, 2024 11:34 am
by stefan.erni
For the Atom S3 the component gLCD_ST7789V1 is working to display text.
The Atom matrix has a 5x5 LED Matrix and it's working with FC WS2812C
For the M5 Dial knob I think an additional component for GC9A01A Display driver is necessary.
The display is also used by other manufacturers
A very good feature of these M5 stack modules is that the IMU MPU6886 is supported von FC
Posted: Wed May 01, 2024 12:22 pm
by BenR
My M5Stack parts have arrived and I've now added a new component for the GC9A01A Display driver. Seems to be working well for me but let me know if you give it a go.
I've added in a few new targets to the ESP Misc section too, should hopefully make things with the M5Stacks a little easier to get started.
Posted: Thu May 02, 2024 9:41 am
by stefan.erni
Thank you very much.
The Atom S3 template is working nice.
the display also works,
but I have to set all the pin.maybe you can make a template with a display
Display only in software mode on my computer is compiling.
a new component is SerialPort.fcpx but no info what it is.
and the display makes an offset. i was able to set and correct this with the other driver
- 2024-05-02_10-22-05.PNG (20.96 KiB) Viewed 1228 times
Set the pin:
- 2024-05-02_10-22-37.PNG (52.27 KiB) Viewed 1228 times
