add slider command as windows
Posted: Fri Dec 03, 2021 1:17 am
by solozerouno
Please add slider command to control app developer.....
thanks solozerouno
Re: add slider command as windows
Posted: Fri Dec 03, 2021 8:19 am
There is a Linear Slider which can be horizontal or vertical
The scale can be changed and you can have a Static Text component displaying the value.
Although the variable type for the slider is float, it will work with bytes integer, longs etc.
- Linear Slider.png (12.13 KiB) Viewed 1579 times
