Page 2 of 2
Re: STM32f030C8 UART Interrupt
Posted: Tue Oct 24, 2023 9:33 pm
by chipfryer27
It turns out I do have a chip, the "R8" which appears to be the big brother of the "C8". It is on a development board I bought a while back. Not sure if I have used it yet though.
If I still have it I'll try and see if I have similar issues.
Posted: Wed Oct 25, 2023 12:02 am
by Alan_37
Hi ,
I would like to explain what this project is going to be about .
I am developing a data Analyzer for split type air-conditioners
data communication analyzer , recorder and playback
between the indoor and outdoor unit .
I was able to make this work but I felt like trying to reinvent the wheel , it got ridiculously complicated just to receive
a string and send it back, the macro receive string and send string should have done this as it dose on other targets
like stm32f4 , Atmega328 and 2560 .
Posted: Wed Oct 25, 2023 9:33 am
by mnfisher
Can you try:
RXTest.fcfx
(15.67 KiB) Downloaded 757 times
Attempting to read a string on UART (1200baud) - with a newline character ('\n' or 10) as end marker - depending how you send the string you might need to change this...
Posted: Wed Oct 25, 2023 10:26 am
by Alan_37
Hi Martin ,
Thanks for your reply ,
split type air-conditioners Example GREE : communicate using 20 Hex bytes @1200 baud every 500ms , and the last byte
is a CheckSum8 Modulo 256 so it is expected to be always different unless nothing changes in the data .
So there is no end marker in the data ,but I will defiantly take a look at your flow see what I can steal from it :) .
Regards ,
Alan
Posted: Wed Oct 25, 2023 10:45 am
by mnfisher
If it's a fixed number of bytes then check 'pos' in the interrupt handler - if you've received 20 bytes then 'stop' (pos = 20 after increment (make buffer bigger and remove the % 20) - process the data and then resume.
This, of course, doesn't allow for transmission errors, timeouts etc - so will need a little extra checking to handle these (in a perfect world - life would be simpler?)
Posted: Wed Oct 25, 2023 11:09 am
by chipfryer27
Just checked my board. Last night I looked online and the info suggested my chip would be similar to yours, but it's actually a STM32F446RET6.
I'll still have a play but it will be later in the week.
Posted: Wed Oct 25, 2023 12:24 pm
by mnfisher
I tested on a Nucleo-F401RE which is as near as I can get. 8Mhz at least?
I swapped to Channel 2 to try and use the Rx Tx pins on A2 and A3 - I couldn't read/write on Tx / Rx pins (using an FTDI chip) - but it did work connecting to the USB port on the board (in my case COM3) with putty.
I modified slightly to display the string on 20 chars received and set an LED on A5 on on interrupt - when displaying the string it turns the LED off again.
It seems to work - but if data is sent whilst printing the string then it stops working (LED no longer lights - interrupt not fired). This is a danger when mashing the keyboard :-) and at such a slow baud rate..
RXTest.fcfx
(16.34 KiB) Downloaded 680 times
Posted: Thu Oct 26, 2023 8:59 am
by Alan_37
I have solved this issue using a circular Buffer , it is now working 100% without any issues .
Thanks to everyone for the help
Alan
