Re: Need help upgrade ESPIDF
Posted: Wed Jul 31, 2024 6:51 pm
Also check your path environment only has the version of python you want to use.
Using Python in C:\Espressif\python_env\idf5.3_py3.11_env\Scripts\
Python 3.11.2
Using Git in C:\Espressif\tools\idf-git\2.44.0\cmd\
git version 2.44.0.windows.1
Checking Python compatibility
Setting IDF_PATH: C:\Espressif\frameworks\esp-idf-v5.3
Adding ESP-IDF tools to PATH...
WARNING: Error while accessing the ESP-IDF version file in the Python environment: [Errno 2] No such file or directory: 'C:\\Espressif\\python_env\\idf5.3_py3.11_env\\idf_version.txt'
C:\Espressif\tools\xtensa-esp-elf-gdb\14.2_20240403\xtensa-esp-elf-gdb\bin
C:\Espressif\tools\riscv32-esp-elf-gdb\14.2_20240403\riscv32-esp-elf-gdb\bin
C:\Espressif\tools\xtensa-esp-elf\esp-13.2.0_20240530\xtensa-esp-elf\bin
C:\Espressif\tools\riscv32-esp-elf\esp-13.2.0_20240530\riscv32-esp-elf\bin
C:\Espressif\tools\esp32ulp-elf\2.38_20240113\esp32ulp-elf\bin
C:\Espressif\tools\cmake\3.24.0\bin
C:\Espressif\tools\openocd-esp32\v0.12.0-esp32-20240318\openocd-esp32\bin
C:\Espressif\tools\ninja\1.11.1\
C:\Espressif\tools\idf-exe\1.0.3\
C:\Espressif\tools\ccache\4.8\ccache-4.8-windows-x86_64
C:\Espressif\tools\dfu-util\0.11\dfu-util-0.11-win64
C:\Espressif\frameworks\esp-idf-v5.3\tools
Requirement files:
- C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt
Python being checked: C:\Espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe
Python requirements are satisfied.
Detected installed tools that are not currently used by active ESP-IDF version.
For removing old versions of idf-driver, idf-python-wheels use command 'python.exe C:\Espressif\frameworks\esp-idf-v5.3\tools\idf_tools.py uninstall'
For free up even more space, remove installation packages of those tools. Use option 'python.exe C:\Espressif\frameworks\esp-idf-v5.3\tools\idf_tools.py uninstall --remove-archives'.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
C:\Espressif\frameworks\esp-idf-v5.3>install
Installing ESP-IDF tools
Updating C:\Espressif\idf-env.json
Selected targets are: esp32s2, esp32c5, esp32c3, esp32c2, esp32s3, esp32h2, esp32p4, esp32, esp32c61, esp32c6
Current system platform: win64
Installing tools: xtensa-esp-elf-gdb, riscv32-esp-elf-gdb, xtensa-esp-elf, riscv32-esp-elf, esp32ulp-elf, cmake, openocd-esp32, ninja, idf-exe, ccache, dfu-util, esp-rom-elfs
Skipping xtensa-esp-elf-gdb@14.2_20240403 (already installed)
Skipping riscv32-esp-elf-gdb@14.2_20240403 (already installed)
Skipping xtensa-esp-elf@esp-13.2.0_20240530 (already installed)
Skipping riscv32-esp-elf@esp-13.2.0_20240530 (already installed)
Skipping esp32ulp-elf@2.38_20240113 (already installed)
Skipping cmake@3.24.0 (already installed)
Skipping openocd-esp32@v0.12.0-esp32-20240318 (already installed)
Skipping ninja@1.11.1 (already installed)
Skipping idf-exe@1.0.3 (already installed)
Skipping ccache@4.8 (already installed)
Skipping dfu-util@0.11 (already installed)
Skipping esp-rom-elfs@20240305 (already installed)
Setting up Python environment
Python 3.11.2
pip 22.3.1 from C:\Espressif\python_env\idf5.3_py3.11_env\Lib\site-packages\pip (python 3.11)
Upgrading pip and setuptools...
Looking in links: c:\Espressif\tools\idf-python-wheels\3.11-2023-03-05
Requirement already satisfied: pip in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (22.3.1)
Requirement already satisfied: setuptools in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (71.0.0)
Installing Python packages
Requirement files:
Ignoring importlib_metadata: markers 'python_version < "3.8"' don't match your environment
Requirement already satisfied: setuptools in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 3)) (71.0.0)
Requirement already satisfied: packaging in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 4)) (24.1)
Requirement already satisfied: click in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 7)) (8.1.7)
Requirement already satisfied: pyserial in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 8)) (3.5)
Requirement already satisfied: cryptography in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 9)) (42.0.8)
Requirement already satisfied: pyparsing in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 10)) (3.1.2)
Requirement already satisfied: pyelftools in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 11)) (0.31)
Requirement already satisfied: idf-component-manager in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (1.5.3)
Requirement already satisfied: esp-coredump in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 13)) (1.11.0)
Requirement already satisfied: esptool in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 14)) (4.8.dev4)
Requirement already satisfied: esp-idf-kconfig in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 15)) (2.3.0)
Requirement already satisfied: esp-idf-monitor in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 16)) (1.4.0)
Requirement already satisfied: esp-idf-nvs-partition-gen in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 17)) (0.1.2)
Requirement already satisfied: esp-idf-size in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 18)) (1.5.0)
Requirement already satisfied: esp-idf-panic-decoder in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 19)) (1.1.0)
Requirement already satisfied: pyclang in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 20)) (0.4.2)
Requirement already satisfied: construct in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 21)) (2.10.70)
Requirement already satisfied: freertos_gdb in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 24)) (1.0.3)
Requirement already satisfied: colorama in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from click->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 7)) (0.4.6)
Requirement already satisfied: cffi>=1.12 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from cryptography->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 9)) (1.16.0)
Requirement already satisfied: requests<3 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (2.32.3)
Requirement already satisfied: urllib3<2 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (1.26.19)
Requirement already satisfied: requests-file<2 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (1.5.1)
Requirement already satisfied: requests-toolbelt in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (1.0.0)
Requirement already satisfied: schema<=0.7.5 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (0.7.5)
Requirement already satisfied: six in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (1.16.0)
Requirement already satisfied: tqdm<5 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (4.66.5)
Requirement already satisfied: pyyaml>5.2 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (6.0.1)
Requirement already satisfied: cachecontrol[filecache]>0.12.6 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (0.14.0)
Requirement already satisfied: contextlib2>0.6.0 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (21.6.0)
Requirement already satisfied: pygdbmi>=0.9.0.2 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from esp-coredump->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 13)) (0.11.0.0)
Requirement already satisfied: bitstring>=3.1.6 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from esptool->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 14)) (4.2.3)
Requirement already satisfied: ecdsa>=0.16.0 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from esptool->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 14)) (0.19.0)
Requirement already satisfied: reedsolo<1.8,>=1.5.3 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from esptool->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 14)) (1.7.0)
Requirement already satisfied: intelhex in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from esptool->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 14)) (2.3.0)
Requirement already satisfied: windows-curses in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from esp-idf-kconfig->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 15)) (2.3.3)
Requirement already satisfied: rich in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from esp-idf-size->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 18)) (13.7.1)
Requirement already satisfied: bitarray<3.0.0,>=2.9.0 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from bitstring>=3.1.6->esptool->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 14)) (2.9.2)
Requirement already satisfied: msgpack<2.0.0,>=0.5.2 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from cachecontrol[filecache]>0.12.6->idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (1.0.8)
Requirement already satisfied: filelock>=3.8.0 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from cachecontrol[filecache]>0.12.6->idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (3.15.4)
Requirement already satisfied: pycparser in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from cffi>=1.12->cryptography->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 9)) (2.22)
Requirement already satisfied: charset-normalizer<4,>=2 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from requests<3->idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from requests<3->idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (3.7)
Requirement already satisfied: certifi>=2017.4.17 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from requests<3->idf-component-manager->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 12)) (2024.7.4)
Requirement already satisfied: markdown-it-py>=2.2.0 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from rich->esp-idf-size->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 18)) (3.0.0)
Requirement already satisfied: pygments<3.0.0,>=2.13.0 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from rich->esp-idf-size->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 18)) (2.18.0)
Requirement already satisfied: mdurl~=0.1 in c:\espressif\python_env\idf5.3_py3.11_env\lib\site-packages (from markdown-it-py>=2.2.0->rich->esp-idf-size->-r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt (line 18)) (0.1.2)
All done! You can now run:
export.bat
C:\Espressif\frameworks\esp-idf-v5.3>export.bat
Requirement files:
idf.py build
C:\Espressif\frameworks\esp-idf-v5.3>idf.py build
Running cmake in directory C:\Espressif\frameworks\esp-idf-v5.3\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=C:\Espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=1 C:\Espressif\frameworks\esp-idf-v5.3"...
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is unknown
-- Didn't find assembler
CMake Error at CMakeLists.txt:2 (project):
No CMAKE_C_COMPILER could be found.
Tell CMake where to find the compiler by setting either the environment
variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
No CMAKE_CXX_COMPILER could be found.
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
No CMAKE_ASM_COMPILER could be found.
variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
-- Warning: Did not find file Compiler/-ASM
-- Configuring incomplete, errors occurred!
See also "C:/Espressif/frameworks/esp-idf-v5.3/build/CMakeFiles/CMakeOutput.log".
See also "C:/Espressif/frameworks/esp-idf-v5.3/build/CMakeFiles/CMakeError.log".
cmake failed with exit code 1, output of the command is in the C:\Espressif\frameworks\esp-idf-v5.3\build\log\idf_py_stderr_output_1472 and C:\Espressif\frameworks\esp-idf-v5.3\build\log\idf_py_stdout_output_1472
C:\Users\Gebruiker>cd C:\Espressif\frameworks\esp-idf-v5.3
WARNING: Error while accessing the ESP-IDF version file in the Python environment: [Errno 2] No such file or directory: 'C:\\Espressif\\python_env\\idf5.3_py3.12_env\\idf_version.txt'
ERROR: C:\Espressif\python_env\idf5.3_py3.12_env\Scripts\python.exe doesn't exist! Please run the install script or "idf_tools.py install-python-env" in order to create it
Python being checked: C:\Espressif\python_env\idf5.3_py3.12_env\Scripts\python.exe
packaging cannot be imported. If you've installed a custom Python then this package is provided separately and have to be installed as well. Please refer to the Get Started section of the ESP-IDF Programming Guide for setting up the required packages.
C:\Espressif\python_env\idf5.3_py3.12_env\Scripts\activate
pip install packaging
python -m pip install -r C:\Espressif\frameworks\esp-idf-v5.3\tools\requirements\requirements.core.txt
deactivate
