Page 2 of 2
Re: FC components and AI (ideas?)
Posted: Wed Jan 21, 2026 9:40 am
by Steve-Matrix
External code can be included in Supplementary Code. See:
https://www.flowcode.co.uk/wiki/index.p ... ntary_Code
Instead of adding the code directly to Flowcode, add statements into Supplementary Code such as the following to point it at external files:
You can then call any external C functions in your code by adding a C icon to your Flowcode macros.
Posted: Mon Jan 26, 2026 7:49 pm
by Bijumon
Created an another component using AI for ESP32 that a single macro call enables direct email dispatch via SMTP (SSL/TLS) for simple notifications like sensor reading or system alerts. Ensure that ESP32 has an active WiFi connection before calling the macro.
Input Parameters
HOST_ADDRESS: SMTP server (e.g., "smtp.gmail.com").
PORT: SSL/TLS port number. (465 for Gmail)
USER_NAME: Full sender email address. (e.g., "
yourname@gmail.com")
PASSWORD: 16-character Google App Password (e.g.,"xgdihlrtexusksta") not login password
DESTINATION: Recipient list (e.g., "
a@mail.com,
b@mail.com")
SUBJECT: The title of the email. (e.g., “Temperature Alert")
MSG_LINE 1 - 4 : Four lines for your data strings (128B per line)
Please note that I have specifically tested this component only on the ESP32 Wroom 32 module with Gmail account
Posted: Mon Jan 26, 2026 8:00 pm
by mnfisher
That's very neat, thankyou.
One suggestion - if you have a string as a parameter to a macro - untick the 'make local copy' check box - this saves duplicating the string (which takes time and memory) - and you can then pass strings of any size.
So - you could have string msg_text[10000] as the parameter to the function - and this is just passed as a 32bit pointer (and a length FCsz_MSG_TEXT) - if the 'make local copy' is ticked it will copy the string to a local (10000 byte) buffer - but otherwise doesn't.
Posted: Mon Jan 26, 2026 8:18 pm
by chipfryer27
This sounds a very cool component. Thank you for creating and sharing.
I hope to test it for myself soom.
