Page 2 of 3
Re: BLACKPILL STM32F411 RTC
Posted: Fri Nov 28, 2025 9:06 am
by LeighM
I've modified your program a little to give us more information with the LED flash.
Can you try this and let me know what the LED does?
Please ensure you use the STARM_CAL_RTC.c from the "STM32F QUESTIONS" thread...
https://www.flowcode.co.uk/forums/viewt ... 918#p18918
Into directory ...
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\STARM
Posted: Fri Nov 28, 2025 1:38 pm
by max.tisc
I just need it to see if the code runs
Posted: Fri Nov 28, 2025 2:46 pm
by LeighM
Yes, but my version will let me know where it stops.
Can you run it and tell me what the LED does?
E.g. LED on, LED off. LED on permanently
Posted: Fri Nov 28, 2025 4:59 pm
by max.tisc
I only see 1 flash of 1 second and then always off, if in the code I invert the position of the UART block with RTC no flashing always off
Posted: Fri Nov 28, 2025 5:09 pm
by max.tisc
by entering the C code
__HAL_RCC_PWR_CLK_ENABLE();
HAL_PWR_EnableBkUpAccess();
__HAL_RCC_LSE_CONFIG(RCC_LSE_ON);
__HAL_RCC_RTC_CONFIG(RCC_RTCCLKSOURCE_LSE);
of the old "STM32F QUESTIONS" thread works still with the old STARM_CAL_RTC.c, now I try with the original FC10 one
Posted: Fri Nov 28, 2025 5:17 pm
by max.tisc
even with the original FC10 STARM_CAL_RTC.c adding the lines of code works
Posted: Fri Nov 28, 2025 6:01 pm
by max.tisc
Now I have another type of problem, everything works fine if I use serial 1 but if I put the software serial for example the tx port C13 nothing comes out, C14 arrives ......, C15 nothing comes out, A0 seems to work fine, are there preferable pins for the software serial? I haven't tried other pins yet
Posted: Fri Nov 28, 2025 6:03 pm
by LeighM
Well done, thanks for that.
I'll compare that with the modified CAL file, not sure when I'll next get some time to do that. But at least you now have a functional work around.
Posted: Fri Nov 28, 2025 6:07 pm
by LeighM
Ah right. I guess we need to look at the Blackpill circuit diagram and 411 datasheet to answer that one
Posted: Sat Nov 29, 2025 3:40 pm
by LeighM
C13 is user LED (active low)
C14 and C15 are RTC crystal
