Page 7 of 7
Re: RC5
Posted: Thu Aug 27, 2026 1:25 am
by ELECTRONICA67
Thanks Martin,
I'm going to start running tests; I'll let you know how it goes in a bit.
Enrique
Re: RC5
Posted: Thu Aug 27, 2026 1:47 am
by ELECTRONICA67
I started by testing the Arduino receiver, but I only have the Arduino set up in Flowcode 10; do you think that’s why I’m getting this error when programming it :?:
And you created the flowchart in Flowcode 11.
Enrique
Re: RC5
Posted: Thu Aug 27, 2026 1:51 am
by ELECTRONICA67
I was able to program it in Flowcode 11.
Re: RC5
Posted: Thu Aug 27, 2026 5:22 am
by ELECTRONICA67
I’ve been testing the Arduino flowchart, but I haven't managed to get it to detect numbers. I used four IR remote controls, though I’m not actually sure if they operate on the same frequency as the receiver; among them is the Xinda remote sold with the Arduino receiver, which, as far as I understand, uses the NEC protocol.
Enrique
Re: RC5
Posted: Thu Aug 27, 2026 6:21 am
by mnfisher
Did you try using the 12f transmitter?
The rc5 protocol seems much less common than NEC format (all the controllers I've tested generate NEC - somewhere i have a one-for-all stick that can do it, just haven't managed to find it)
The good news maybe is that i did a NEC decoder with Jan a few years ago.
Re: RC5
Posted: Fri Aug 28, 2026 3:58 am
by ELECTRONICA67
I’m going to test the PCB I made for programming an RC5 transmitter; afterwards, I’ll test the PIC16F1847 flowchart.
You also mentioned that you and Jan built a decoder...
It’s great that the weekend is just a day away. :)
