USBtiny error
Posted: Tue Feb 01, 2022 3:11 pm
by sccadmin
Hi, I'm trying to program a Grove Beginner Kit (arduino) but gives me the error below.
Please help. I'm not sure why I keep getting the USBtiny error.
Target folder: \\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode
Source name:   \\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.fcfx
Title:
Description:
Device:        AVR.ATMEGA.ATMEGA328P
Generated by:  Flowcode v9.2.0.33
Date:          Tuesday, February 01, 2022 15:10:14
Users:         50
Registered to: sccadmin (32428053)
Licence key: 0QPZKG
   NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Using <E-Blocks> inbuilt settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avra.bat  "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" atmega328p "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.elf" "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.c" "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.lst"
'\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode'
CMD.EXE was started with the above path as the current directory.
UNC paths are not supported.  Defaulting to Windows directory.
C:\Windows>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D7958998291880A09BBE74CF7BA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EEFF12703F3DAF67B119A5A5B069403B38249A6C4D8A1304B09A437E7E2D43FD26DF891DB3086C82D6
C:\Windows>REM REVISION: 1.0
C:\Windows>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
C:\Windows>REM DATE: 29\03\2021
C:\Windows>REM DIR: FCD\AVR\batchfiles\avra.bat
C:\Windows>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.elf" "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.c" -lm -Wl,-gc-sections
C:\Windows>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-objdump.exe" -S "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.elf"  1>"\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.lst"
C:\Windows>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-size.exe" -B -d "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.elf"
   text	   data	    bss	    dec	    hex	filename
    152	      0	      0	    152	     98	\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.elf
Compilation successful!
Using <E-Blocks> inbuilt settings for linker
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avrb.bat  "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.elf" "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.hex" "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.cof"
C:\Windows>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B69041F19754DEA3580B6825E5D6A5C09874F305C640EF477B79E0C7881D2E5EEC9BD6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D795899824EF872725113B645F175A82BBF7DF194C31451F662291FA2302B8E00B0793B98DE54674FED6890F09D29E6D6AF5F4CDA2A0B069D1A731E4BF7CAEBD6A00B6313A3554E78FBF27EB2E2AB377A2B2C9B1D3B75C13EB27ADD422C3050DA273BE4EE0394535DE0D901F49597144CF394E33BC8A5C5ECC46A5F0EA3E761B0B04467EFC0CE2C344F21BA45
C:\Windows>REM GUID: C4F77EBB-EDB0-4261-B01E-F0B1AB94E03A
C:\Windows>REM DIR: FCD\AVR\batchfiles\avrb.bat
C:\Windows>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avr-objcopy" -O ihex -R .eeprom  "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.elf" "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.hex"
HEX file creation successful!
Using <E-Blocks> inbuilt settings for programmer
Launching the programmer...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avrc_usbtiny.bat  "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\" AVRDUDE m328p atmega328p "\\scc-fs-hf4\Students$\stu2122\S298257\Desktop\Flowcode\test.hex" "test.hex" 0 3 255 255 255
C:\Windows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
C:\Windows>REM GUID: A9214695-C8E9-4EAE-A1FD-7E32BFDC5003
C:\Windows>REM DIR: FCD\AVR\batchfiles\avrc_usbtiny.bat
C:\Windows>"C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\bin\avrdude.exe" -p m328p -Pusb -c usbtiny -U flash:w:"test.hex"
avrdude.exe: Error: Could not find USBtiny device (0x1781/0xc9f)
avrdude.exe done.  Thank you.
Error returned from [avrdude]
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\AVR\batchfiles\avrc_usbtiny.bat reported error code 0x1
Autoclose turned off
FINISHED
Re: USBtiny error
Posted: Tue Feb 01, 2022 3:37 pm
by p.erasmus
Hi.
You FC can not find your board it seems to program it, did you select the correct coms port for your board in the Project properties
Re: USBtiny error
Posted: Tue Feb 01, 2022 3:46 pm
Hi.
After selecting the correct hardware e.g Arduino Uno (You don't want to select Atmega chip), it sounds you have either not selected the Ardunio compatible port within Build ribbon, Project options, .
At the bottom right you should see Programmer Port:
It should not show n/a.
Make sure you can select the hardware comport.
If you can't then you might not have the correct driver installed?
Can you check with your device manager and see if there is a new port within the Ports section with the Seeduino plugged in or a yellow ! somewhere.
Then they disappear with your Seeduino unplugged?
If you have not already installed the driver, you will ever require CH340 or CP210x depending on what version board you have.
See here
I have edited your post to place the text output from the compiler within code tags.
It takes up much less room.
Edit:
Peter beat me to it, but two replies are better than none.
Re: USBtiny error
Posted: Thu Feb 03, 2022 3:36 pm
by sccadmin
Brilliant! It's all working now, thank you so much for the support.
P.s. both answers were amazing :D
Re: USBtiny error
Posted: Thu Feb 03, 2022 6:26 pm
Hi sccadmin,
You're welcome.
Matrix TSL is so lucky that valued contributors voluntarily help forum members out.
