8 big pic ssd1306 error not compile.
Posted: Wed Jan 13, 2021 5:41 am
Hi Sir,
I am currently using 30 days trial version of V9. I am getting below error while compiling. Its a simple test program to display "Hi" using OLED SSS1306 but its not converting the file to Hex. Kindly advise what could be the issue.
Target folder: E:\flowcode\FlowcodeV9\16F15059 OLEDTEST
Source name: E:\flowcode\FlowcodeV9\16F15059 OLEDTEST\OLEDTEST.fcfx
Title: OLEDTEST
Description:
Device: PIC.16F.16F1509
Generated by: Flowcode v9.0.0.23
Date: Wednesday, January 13, 2021 11:09:54
Users: 1
Registered to: siliconpowersystemR (siliconpowersystemR)
Licence key: DTEST\
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\batch\pic_xc8_comp.bat 16F1509 "E:\flowcode\FlowcodeV9\16F15059 OLEDTEST\" "OLEDTEST"
E:\flowcode\FlowcodeV9\16F15059 OLEDTEST>C:\PROGRA~2\Flowcode\Common\COMPIL~1\picv2\batch\..\pic\bin\xc8.exe --chip=16F1509 "OLEDTEST.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
C:\PROGRA~2\Flowcode\Common\COMPIL~1\picv2\pic\bin\picc --chip=16F1509 OLEDTEST.c --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
using updated 32-bit floating-point libraries; improved accuracy might increase code size
OLEDTEST.c: 399: (1250) could not find space (128 bytes) for variable _FCV_0cc51_gLCD_SSD1306_i2c1__DRAM4
OLEDTEST.c: 399: (1262) object "_FCV_0cc51_gLCD_SSD1306_i2c1__DRAM4" lies outside available data space (warning)
OLEDTEST.c: 400: (1250) could not find space (128 bytes) for variable _FCV_0cc51_gLCD_SSD1306_i2c1__DRAM3
OLEDTEST.c: 400: (1262) object "_FCV_0cc51_gLCD_SSD1306_i2c1__DRAM3" lies outside available data space (warning)
OLEDTEST.c: 401: (1250) could not find space (128 bytes) for variable _FCV_0cc51_gLCD_SSD1306_i2c1__DRAM2
OLEDTEST.c: 401: (1262) object "_FCV_0cc51_gLCD_SSD1306_i2c1__DRAM2" lies outside available data space (warning)
OLEDTEST.c: 402: (1250) could not find space (128 bytes) for variable _FCV_0cc51_gLCD_SSD1306_i2c1__DRAM1
OLEDTEST.c: 402: (1262) object "_FCV_0cc51_gLCD_SSD1306_i2c1__DRAM1" lies outside available data space (warning)
OLEDTEST.c: 403: (1250) could not find space (128 bytes) for variable _FCV_0cc51_gLCD_SSD1306_i2c1__DRAM0
OLEDTEST.c: 403: (1262) object "_FCV_0cc51_gLCD_SSD1306_i2c1__DRAM0" lies outside available data space (warning)
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\batch\pic_xc8_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
Title: OLEDTEST
Description:
Users: 1
Licence key: DTEST\
FINISHED
