Flowcode and CNC Machine Component
Posted: Mon Sep 19, 2022 10:32 am
by stefan.erni
Flowcode has a component CNC Machine and Matrix has some CNC Machine on offer.
Is there a CNC machine that can be controlled with FC9?
Not to mill parts but to demo a machine.
Re: Flowcode and CNC Machine Component
Posted: Mon Sep 19, 2022 10:41 am
by BenR
Hello Stefan,
Flowcode has a CNC component which is basically a 3D model you can move around, you can find more information on it here.
https://www.flowcode.co.uk/wiki/index.p ... NC_Machine
Flowcode can also be used to control a real world CNC machine if this is what you're after.
Probably just a case of opening a .nc G code file and then sending the data line by line to a COM port and maybe awaiting a response. I have a Grbl CNC machine and that's basically what the Grbl software does.
Posted: Fri Nov 11, 2022 2:52 pm
by stefan.erni
Thats already help Thank you. The controller accept I2C commands or can switche do grbl file.
I'll try connect the wire and move the motors first...
Posted: Tue Nov 22, 2022 3:44 pm
by stefan.erni
I tried the example but the machine doesn't move a bit.
just pressed F5 to start the simulation. Do I have to consider anything else?
Posted: Wed Nov 23, 2022 10:21 am
by BenR
Hi Stefan,
Many thanks for letting us know I've now hopefully resolved the problem for you via a library update.
Posted: Wed Nov 23, 2022 1:21 pm
by stefan.erni
Yes perfect. It's moving again.
The CNC machine is really nicely made.
But I can't find the components in FC App Developer.
Are there mechatronics and scenarios for the FC App Developer?
Not In FC App Developer
- 2022-11-23_13-58-37.png (26.17 KiB) Viewed 2968 times
- 2022-11-23_14-07-53.png (22.06 KiB) Viewed 2968 times
Posted: Wed Nov 23, 2022 5:36 pm
by BenR
The CNC and some other scenarios require stepper motors to move the various components around on the panel and the stepper motors require pins for movements. I'll have a think on if there is a nice way to replicate this for app developer. Maybe some sort of X,Y,Z, translator component?
Posted: Thu Nov 24, 2022 11:02 am
by stefan.erni
I have a few suggestions and wishes
the first would be:
The Stepper_nema8 for FC App developer.
With the target handle I can just put the motor pulley over the stepper axis and select shape1 as target
The pulley will turn like the stepper.
imported motor pulley
- 2022-11-24_11-52-58.png (115.23 KiB) Viewed 2948 times
- 2022-11-23_19-03-24.png (30.02 KiB) Viewed 2948 times
