SK6812
Posted: Fri Sep 23, 2022 6:33 pm
by jgu1
Hi!
I try to test the SK6812 RGBW component. When I added the component to the 2D or 3D dashboard panel it is not possible to se the led. If I with luck am able to click on the component on the dashboard I am able to see the properties and try to increase the size with and high nothing happend. What am I doing wrong please?
Br jorgen
Re: SK6812
Posted: Fri Sep 30, 2022 4:46 am
by jgu1
Hi again. Any tips,what am I do wrong, please?
Br Jorgen
Re: SK6812
Posted: Fri Sep 30, 2022 8:13 am
by chipfryer27
It appears to be a v9 bug. It works fine in v8.
I created a 1Dx 10 string in v8, saved and then opened in v9. I had to mess around with properties to get it displaying. Hopefully the attached will be of some use.
SK6812.fcfx
(7.9 KiB) Downloaded 114 times
EDIT...
Had a further play. In v9 if you add the component then go to Project explorer and click on components, highlight the SK6812 and right-click-select the component will show in the panel, Well the positioning bars will. If you now go to the component properties and set Column Spacing to 1 then on mine at least you will see a string on the panel.
Re: SK6812
Posted: Fri Sep 30, 2022 11:22 am
by BenR
I think I've fixed it properly now so it should correctly appear when you drag it on.
I've also updated other similar components as they had similar issues.
Re: SK6812
Posted: Fri Sep 30, 2022 3:23 pm
by chipfryer27
Seems to work OK now.
Thanks.
Re: SK6812
Posted: Fri Sep 30, 2022 5:56 pm
by jgu1
Thank you Ben. ;)
Jorgen
