display IlI9341
Posted: Sat Jan 23, 2021 10:52 pm
by Osta
I have a problem with the text output on the display IlI9341
Re: display IlI9341
Posted: Tue Jan 26, 2021 3:38 pm
by BenR
Hello Osta,
Have you tried on the hardware to see if it does the same thing there?
Any you using the latest component updates using Help -> Check for updates menu?
I have a display here I can try if you're still getting the problem.
Re: display IlI9341
Posted: Mon Feb 01, 2021 12:31 pm
by Osta
Hello Ben!!!
Now there is an opportunity to answer.
Yes, I always debug in the proteus and then in the gland.
Updated all libraries the result is the same
Re: display IlI9341
Posted: Mon Feb 01, 2021 4:28 pm
by BenR
Took me a while but testing here and it's all working correctly. Have you used the Help -> Check for updates to ensure you are using the latest version of the component?
- GLCD.jpg (24.17 KiB) Viewed 5776 times
Re: display IlI9341
Posted: Wed Feb 03, 2021 11:53 am
by Osta
Yes updated!
Everything became normal !!!
Thanks!!!
Best regards, Ost.
