Page 1 of 2
PIC16F project not compiling to HEX
Posted: Sun Feb 26, 2023 5:01 pm
by pschoon
I imported my working FC9 project into FC10.
Now when compiling it to HEX i get an Error..
D:\SC-Server\Projecten\xx\xx\Flowcode\V1.3_230207\FC10>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8.exe" --chip=16F18857 "V1.3_230207.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\pic\bin\picc --chip=16F18857 V1.3_230207.c --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
D:\SC-Server\Projecten\xx\xx\Flowcode\V1.3_230207\FC10\V1.3_230207.h:
549: #warning WS2811 Timings are less than 10 instructions, timing may be incorrect at the current clock speed
^ (162) #warning: WS2811 Timings are less than 10 instructions, timing may be incorrect at the current clock speed (warning)
724: 0x0101
^ (195) expression syntax
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_RMT.c:
67: void FC_CAL_RMT_TX_1 (void);
(984) type redeclared ^
^ (1098) conflicting declarations for variable "FC_CAL_RMT_TX_1" (C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_RMT.c:67)
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
It seems to be halted at the RMT CAL function.
It's not clear to me what kind of cal function this is!
V1.3_230207.fcfx
(297.31 KiB) Downloaded 761 times
Re: PIC16F project not compiling to HEX
Posted: Sun Feb 26, 2023 5:36 pm
by kersing
Please do not use fancy colors when composing a message. Other users with a different theme are unable to read such messages.
Posted: Mon Feb 27, 2023 8:02 pm
by pschoon
sorry..
Posted: Tue Feb 28, 2023 5:37 pm
by WingNut
If its any help I get a the following output - which is slightly different than your but still indicates a timing issue
C:\Users\Norma\Downloads>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8.exe" --chip=16F18857 "V1.3_230207.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
C:\Users\Norma\Downloads\V1.3_230207.h:
724: 0x0101
Posted: Wed Mar 01, 2023 9:14 am
by Steve-Matrix
It looks like a bug in one of the components. There should be a library update for this soon.
Posted: Wed Mar 01, 2023 10:21 am
by Steve-Matrix
Sorry - my mistake. It's not a bug in the component. It's because comments have been added to the LUT data which stop the compiler seeing the commas.
0x0011 //Make EEProm Valid,
0x0101 //RampStart,
0x0296 //RampTime,
0x0302 //Standby,
0x0401 //AutoNull,
To fix this, put the commas straight after the values and before your comments like this:
0x0011, //Make EEProm Valid
0x0101, //RampStart
0x0296, //RampTime
0x0302, //Standby
0x0401, //AutoNull
Posted: Wed Mar 01, 2023 8:31 pm
by pschoon
Hi Steve,
Thanks for looking in.
It's not working for me. Took out all comments but still the same error..
Registered to: pschoon (51737870)
Licence key: PxxxxA
https://www.flowcode.co.uk
Using <PICkit2 PK2CMD External Power> inbuilt settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\" 16F18857 "D:\SC-Server\Projecten\xx\xx\Flowcode\V1.3_230207\FC10\Test\" "V1.3_230301"
D:\SC-Server\Projecten\xx\xx\Flowcode\V1.3_230207\FC10\Test>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF67459835899A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF57461C3AC48896F1350CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE49AB5BB4E7889ABE01CC1B191673976A728A9FC6E025EAD10C9FBA1F01A7E45B08B65E7F68830DD9
D:\SC-Server\Projecten\Airtender\VacuumMeter\Flowcode\V1.3_230207\FC10\Test>REM REVISION: 1.0
D:\SC-Server\Projecten\Airtender\VacuumMeter\Flowcode\V1.3_230207\FC10\Test>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
D:\SC-Server\Projecten\Airtender\VacuumMeter\Flowcode\V1.3_230207\FC10\Test>REM DATE: 08\08\2022
D:\SC-Server\Projecten\Airtender\VacuumMeter\Flowcode\V1.3_230207\FC10\Test>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
D:\SC-Server\Projecten\Airtender\VacuumMeter\Flowcode\V1.3_230207\FC10\Test>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8.exe" --chip=16F18857 "V1.3_230301.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\pic\bin\picc --chip=16F18857 V1.3_230301.c --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
D:\SC-Server\Projecten\Airtender\VacuumMeter\Flowcode\V1.3_230207\FC10\Test\V1.3_230301.h:
558: #warning WS2811 Timings are less than 10 instructions, timing may be incorrect at the current clock speed
FINISHED
V1.3_230301.fcfx
(306.89 KiB) Downloaded 609 times
Posted: Wed Mar 01, 2023 10:16 pm
When I compile your project file I get:
0: (1347) can't find 0x2 words (0x2 withtotal) for psect "stringtext108" in class "STRCODE" (largest unused contiguous range 0x1)
updated 32-bit floating-point routines might trigger "can't find space" messages appearing after updating to this release; consider using the smaller 24-bit floating-point types
0: (1347) can't find 0x2 words (0x2 withtotal) for psect "stringtext109" in class "STRCODE" (largest unused contiguous range 0x1)
0: (1347) can't find 0x2 words (0x2 withtotal) for psect "stringtext110" in class "STRCODE" (largest unused contiguous range 0x1)
This means your target device has not got enough memory free.
After modifying the default xc8 batch file I got:
Program space        used  752Ah ( 29994) of  8000h words   ( 91.5%)
    Data space           used   C61h (  3169) of  1000h bytes   ( 77.4%)
    EEPROM space         used     0h (     0) of   100h bytes   (  0.0%)
    Data stack space     used     0h (     0) of   382h bytes   (  0.0%)
    Configuration bits   used     5h (     5) of     5h words   (100.0%)
    ID Location space    used     0h (     0) of     4h bytes   (  0.0%)
That is a large project taking lots of memory.
To Replace the batch file:
Rename the pic_xc8_comp.bat to something like pic_xc8_comp ORG.bat, so it can be kept.
Extract the contents of the attached zip file into the above directory, then recompile.
I suspect you are getting a different result to other people as your components might not be upto date?
Make sure the Flowcode component library is fully up to date by Help>Library Updates... Change the Files in-use to full database. After updating reload your project
Posted: Thu Mar 02, 2023 12:28 pm
The batch file has now been pushed onto the update system.
So there is no need to download the zip file.
Just do a full database update as described in my previous post, then the project should compile for you.
As this has not been a bug, I have moved this topic from the bugs section.
Posted: Thu Mar 02, 2023 8:03 pm
by pschoon
I did a full database update and YES it works.
Many thanks..
:D :D :D
