SHT21 macro error
Posted: Tue Mar 14, 2023 3:06 am
by niedian
SHT21 macro error. During the simulation process, the obtained data is basically unchanged. Always show a fixed value.
Re: SHT21 macro error
Posted: Tue Mar 14, 2023 9:20 am
by Steve-Matrix
I'm not familiar with that component, but when I run a simulation the values displayed on the LCD are not fixed and do change. However, the values are not the same as those on the SHT21 component. The Humidity changes between -6.00 and -5.88, and the Temperature changes between -46.8 and -46.5.
Posted: Tue Mar 14, 2023 9:55 am
Hello, What version of flowcode are you using?
When you start a new topic can you use either the 9 or 10 post icon please.
- Post Icons.png (10.15 KiB) Viewed 6047 times
Posted: Tue Mar 14, 2023 11:57 pm
by niedian
I'm using V10, is the range of SHT21 only that small?
Posted: Wed Mar 15, 2023 9:01 am
Thank you for the spot.
It is a bug and I have now fixed it, so you will get the full range that the component shows.
The fixed component will be pushed onto the update system as soon as possible.
If you would like to try the component before the updates are pushed.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Replace the existing files with the attached files.
If you run any component updates, then the components you added will be overwritten.
Posted: Wed Mar 15, 2023 2:19 pm
I can confirm the updated component has been pushed onto the update system.
If you run a component update The component I posted will be replaced with the latest version.
Posted: Wed Mar 15, 2023 5:07 pm
by jgu1
Hi Martin!
Sorry for brake in
The value change now in simulation after update, but if I try to move the component in the 2D panel, it is not possible and if I try to increase them it not possible or make a strange size?
Jorgen
Posted: Wed Mar 15, 2023 5:48 pm
hello Jorgen.
I just added a new 2D panel and it moved OK.
It just ended up in the top left corner. After dragging and resizing all was good.
Try this.
Drag the component you wish to move to the bottom right of the center cross of the legacy panel and then use the move command.
If the component does move out of view just set Y and X locations to 0, 0 from the properties.
Posted: Wed Mar 15, 2023 7:04 pm
by jgu1
Well ok Martin. I just open niedian“s examble, yes it work with new panel, thank“s
