After update!
Posted: Fri May 19, 2023 7:27 pm
Hi!
I have worked on a project for a while with an Ili9488 and an ESP 32, before Ben has made the Highspeed 80 mhz prescaler. The display has been fairly fast with the pin config I use in this project, up to 30 mhz working ok.
Now I have program the device again, not change anything, but now the display is suddently extremly slow
I have a backup backup try to program this also, same.
I started the project in FC9 and continue in FC10 all work until now. I try to program with FC9 (older) then it is fast.
Just like prescaler is on 6mhz.
please could this be fixed back again??
A project I have had a pcb manufactured for and spent many hours on this project, so not easy to change to the highspeed SPI
Jorgen
Jorgen
