Page 1 of 2
Can't compile the ESP32 With Display gLCD TLT9341
Posted: Mon Jun 12, 2023 7:52 am
by monie
Hello everyone
Can anyone here see where it's going wrong?
And how can I fix Flowcode v10 so I can run the file below?
ESP32Ili9341GpsaFloat_OK.fcfx
(44.3 KiB) Downloaded 451 times
And Attached filet:
Compiler Messages.pdf
(44.58 KiB) Downloaded 595 times
Hope you will be helpful with suggestions to fix Flowcode v10 So I can use the ESP32 device.
With best regards
Monie
Re: Can't compile the ESP32 With Display gLCD TLT9341
Posted: Mon Jun 12, 2023 8:45 am
Hi Monie.
Your project compiles OK for me, so it could be down to your ESP toolchain installation.
Have you tried just compiling a blank project?
I have updated the Wiki ESP32 toolchain guide for starting afresh, I.e. uninstalling the whole toolchain and starting again.
Posted: Mon Jun 12, 2023 8:19 pm
by monie
Hi medelec35
I have gone through your suggestion but to no avail.
See below!
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat reported error code
0x1
Attached filet:
(44.08 KiB) Downloaded 464 times
Do you have any suggestions?
So I can upload my codes without any problem :-)
Best regards
Monie
Posted: Mon Jun 12, 2023 8:43 pm
by chipfryer27
Your error message informs that Python is not installed. You must have that installed to use the ESP.
Please follow Medelec's instructions exactly and don't leave your PC alone as you may miss an option during the process.
Posted: Tue Jun 13, 2023 7:37 am
by monie
Gets the following below all the time...
ERROR: Python is not installed...?
============================== Toolchain Check ==============================
git version 2.21.0.windows.1
ESP toolchain found at "C:\esp-idf\"
Building TestDisplayI2CRSP32-OK-Virker ...
Error: The following tools are not installed in your environment.
python
Please use the Windows Tool installer for setting up your environment.
Download link: https://dl.espressif.com/dl/esp-idf/ - Which of the options should I choose?
Using Windows v11
For more details please visit our website: https://docs.espressif.com/projects/esp ... setup.html
'idf.py' is not recognized as an internal or external command,
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat reported error code 0x1
Autoclose turned off
FINISHED
Tried to install "Python" but no luck.
Keep getting the above message.
Do you have a suggestion?
Posted: Tue Jun 13, 2023 8:08 am
hi monie.
If you look at the instructions,
you will see that part of the esp-idf-tools-setup-2.3.exe install process is to install Python if it's not already installed.
It's the second image down.
Python is the first item that's installed.
None, as the toolchain is downloaded from our website.
chipfryer27 is spot on, you can't start the install then leave your PC, as there will be elevated requests and prompts for the destination paths, etc.
Posted: Wed Jun 14, 2023 6:24 pm
by monie
Hi medelec35
Which of the options is best to choose when using Windows 11 "ESP-IDF Windows Installer Download"
Open Source IoT Development Framework for ESP32
Download
See below 1 og 2
1: Attached filet:
TestDisplayI2CRSP32.fcfx
(12.64 KiB) Downloaded 455 times
2: Attached filet:
(44.63 KiB) Downloaded 510 times
Hope you will still be helpful with suggestions to fix Flowcode v11 so I can use the ESP32 device.
I have followed very closely
your proposal. But I can't get TestDisplayI2CRSP32 to work
With best regards
Monie
Posted: Wed Jun 14, 2023 8:14 pm
Hi, monie.
Flowcode v10 is not broken as I have tried your project on a win10 PC and a win11 laptop and on both setups I get compiled successfully.
I have a couple of suggestions.
1. Run ESP-IDF which should be on your Desktop and enter
 idf.py --version
then
Git --version
then
 python --version
and finally
install.bat esp32
Can you let me know what the reported idf, git, and python versions are please?
Also post within code tags the text from
install.bat esp32
2. Make sure the Flowcode component library is fully up to date by Help>Library Updates... Change the Files in-use to full database.
After updating reload your project.
Try compiling again
Posted: Wed Jun 14, 2023 8:32 pm
by monie
Hi medelec35
User:
1: python-3.11.4-amd64
2: Git-2.41.0-64-bit
3: esp-idf-tools-setup-2.3
4: c:\esp-id
Yes = Flowcode component library is fully up to date by Help>Library Updates... Change the Files in-use
With best regards
Monie
Posted: Wed Jun 14, 2023 10:34 pm
Hi monie.
For 1.
When I enter
idf.py --version
I get
ESP-IDF v4.2.4-233-gfe907a6c39-dirty
I don't know why yours is so different if you followed Wiki ESP32 toolchain guide step by step
