Page 1 of 4
X9C103 (FIXED)
Posted: Tue Sep 12, 2023 10:12 pm
by ELECTRONICA67
Please can help me ?
I am test the potentiometro X9C103 but when copila to .hex say error.
Enrique
Re: X9C103
Posted: Tue Sep 12, 2023 11:22 pm
Hello, many thanks for the report
The component fix will be pushed onto the update system ASAP.
If would you like to test before then, Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
If you run any component updates, then the components you added will be overwritten.
Can you let me know if it works for you, please?
Re: X9C103
Posted: Wed Sep 13, 2023 1:19 am
by ELECTRONICA67
Hi Martin, not work, say error when copile.
Enrique
Re: X9C103
Posted: Wed Sep 13, 2023 5:16 am
by ELECTRONICA67
Sorry Martin, I responded to you several times. . .I didn't know that each question or answer on a topic had to be approved.
I expected to see the reply published when it was sent to the forum. I see that the rules have changed regarding past forums.
Enrique
Re: X9C103
Posted: Wed Sep 13, 2023 7:48 am
by chipfryer27
Hi Enrique
When a forum member first starts to post, the first few need to be approved before they are shown as a way to help reduce spam messages etc. When I logged in this morning I saw your posts and approved (I also deleted your duplicated ones).
Re: X9C103
Posted: Wed Sep 13, 2023 8:01 am
Hi Enrique,
Your project file X9S103V10.fcfx did have an error for me, but now I can compile it to hex, after the component has been modified.
When you added the modified file did you get a prompt to override the original file and did you reload your project file before compiling?
If that is the case, can please attach your X9S103V10.c and X9S103V10.msg.txt files that are in the same directory as X9S103V10.fcfx
Re: X9C103
Posted: Wed Sep 13, 2023 7:51 pm
by ELECTRONICA67
I can now compile the program to .hex, I am going to program the chip to test it, did you mention that there was an error in the flowchart ?
Enrique
Re: X9C103
Posted: Wed Sep 13, 2023 9:36 pm
No, there was indeed a bug within the digital pot, which I have fixed.
I have not tested your project on hardware.
at least you can now compile which is great!
Re: X9C103
Posted: Mon Sep 18, 2023 10:34 pm
by ELECTRONICA67
I restarted the test of the X9C103 Potentiometer, but I cannot increase or decrease the value of the resistance, the value remains fixed at 3.7 kohm, could you help me? I attach the flow chart.
Enrique
Re: X9C103
Posted: Tue Sep 19, 2023 8:35 am
Hi Enrique.
I will investigate and see if I can spot what's going on.
