dht22 update with possible problem
Posted: Sat Feb 10, 2024 3:27 pm
by aderito
Hi, after updating this sensor's library I started having problems in a project I'm developing and where I'm using this dht22.
I went to the component library and changed it to the previous version and then it started working correctly again.
I hope to help someone with the same problem and also the programmer find the solution.
in the return variable of the "samplesensor" macro I get the number: 79.
I don't know if it helps anything..... :?
Re: dht22 update with possible problem
Posted: Mon Feb 12, 2024 10:48 am
by Steve-Matrix
Sorry about that. What target chip and clock speed are you using?
And you can revert the version of the component via the Library Updates screen (tick "show up-to-date files" and select "6" in the "New revision" column).
Posted: Wed Feb 14, 2024 9:29 pm
Can you read this post, please.
Posted: Thu Feb 29, 2024 5:19 pm
by aderito
Steve-Matrix wrote: ↑
Hi Steve, sorry I'm only replying now, I've been away at work and without my hobby bench.....
I'm using a pic18f4620 running at 40Mhz.
In the dht22 component I was already using the groove version when an update appeared and it was after updating that it stopped working.
After that I reverted to the previous version and it worked again...
