DHT22 Issues
Posted: Sat Feb 10, 2024 5:08 pm
We are aware of DHT22 issues.
If fixed for some target devices, it will not work on others.
I have got a temporary solution for people to try.
I have added an additional property called Check Threshold to allow the DHT22 to work on more devices
If you can't get it to work, I also have also got a debug version that will show you the range in which the Check Threshold should be set at for the component to work.
You can ask for that version, and I will post it
For the 16F18877 the range is very tight.
Here are values for some target devices:
Arduino 165 - 181
TTGO 157 - 177
16F18877 196 -197
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
Place the attached component.
If you run any component updates, then the component you added will be overwritten, so it will stop working again.
I hope this helps as a temporary fix.
If this does work for your target devices, then I will make the same changes for the Grove version.
Re: DHT22 Issues
Posted: Sat Feb 10, 2024 8:48 pm
by jgu1
Hi Martin!
Thank´s I test tomorrow. ;)
Jorgen
Re: DHT22 Issues
Posted: Sun Feb 11, 2024 8:36 am
by jgu1
Hi Martin!
I have perform some test with arduino and a Pic16F876 with your new component.
Arduino: it work with your recommended setting, but it is unstable, sometime it stop work and sometime the display show for the Hum -3247,5 after some second it run again.
Pic16f875 20mHz not possible to get i work no matter what the setting, value is set.
If I in update roll back to the "Grove DHT22 and DHT22" ver. 3 it work stable for both, Arduino and Pic. Maybe you could have a look in the ver. 3 component ;)
I have not test the other devices.
If I can help you,let me know.
Jorgen
Re: DHT22 Issues
Posted: Wed Feb 14, 2024 9:28 pm
Hi Jorgen.
Sorry for the delay.
Can you and anyone else who has a DHT22, try the attached component please?
Instructions can be found here for anyone who have not added a component yet.
For me, the updated component is working on the Arduino Uno, ESP32 Lolin and 16F18877 at 19MHz and above.
Re: DHT22 Issues
Posted: Thu Feb 15, 2024 6:33 pm
by jgu1
Hi Martin!
No probs :D
Perform a test and you hear
Jorgen
Re: DHT22 Issues
Posted: Thu Feb 15, 2024 6:51 pm
Thanks Jorgen.
We put a fair bit of time and effort into it, especially Steve.
Fingers crossed.
Re: DHT22 Issues
Posted: Thu Feb 15, 2024 7:00 pm
by jgu1
Hi again!
I have two testboard up running with the DHT22 not the Grove. One with Pic16f876 20 mHz and one with an Arduino Uno.
Just perform a test with these devices, working perfect now ;)
I have not test the other devices, if no other do, I can do it later ;)
As always, thank´s for your and Steve´s job, well done. Push it to update.
By the way, think it is long time we have heard from Benj, hopefully he still work for MM? :D
Br jorgen
Re: DHT22 Issues
Posted: Fri Feb 16, 2024 1:05 pm
by Steve-Matrix
jgu1 wrote: ↑
Yes - Ben is still here, but splitting his time amongst many different projects.
