Hello Matrix Team,
Hello Ben,
I belive I need some help regarding the ESP32 toolchain installation and the compile inside FC9.
Unfortunately I must install my prof. pack on a new PC because the old one crashed.
The ESP32 compiler is giving me the follwing error message:
Target folder: C:\ESP32\Dummy_Test
Source name: C:\ESP32\Dummy_Test\Test1.fcfx
Title:
Description:
Device: ESP.ESP32.ESP32_WROOM_32
Generated by: Flowcode v9.3.1.36
Date: Friday, June 14, 2024 20:55:33
Users: 1
Registered to: dvcam99 (98467282)
Licence key: deleted here from me due to security!!!
https://www.flowcode.co.uk
Using FCD settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_build.bat "C:\ESP-IDF\" "Test1" "C:\ESP32\Dummy_Test\" esp32s_sdkconfig esp32
C:\ESP32\Dummy_Test>REM CRC: 0796FC1E6A776AF9156B257209C35258CE7C28B3EC20AEA2C632DB392A0E4BFD5B3F53B21811978F7B21FE4085045A7E774D1D3D69D8A99EE7320EAE740A5DB6FE0D8D4660AC0314F98C28BCA92AF856EFD1DB5B777140BC4D00059D795899827D9F76D89626FBC8B199900461C78937B42DEF8219F63A24580137A2F6C8FDB7553324EFF791947E8AB6FFD612B81BAA97C798A8F1CFC189DE5D38517747C774AF2DD6F839BAECF83F7F994C7164CE77868F480396BDEF2F2C3050DA273BE4EE6FE0BB589D1229A5E37B217FF86DBD72A01B8FBC49BE02BFA3608A0B0CE69F969622A912E6E6A2FB
C:\ESP32\Dummy_Test>REM REVISION: 4.0
C:\ESP32\Dummy_Test>REM GUID: 955EA920-4961-4C53-BA6B-EF4AF66BB4C2
C:\ESP32\Dummy_Test>REM DATE: 29\03\2021
C:\ESP32\Dummy_Test>REM DIR: FCD\ESP\Batch\esp32_build.bat
Building Test1 ...
Checking Python compatibility
Setting IDF_PATH: C:\ESP-IDF
Adding ESP-IDF tools to PATH...
WARNING: Error while accessing the ESP-IDF version file in the Python environment: [Errno 2] No such file or directory: 'C:\\ESP-IDF\\-tools\\python_env\\idf5.1_py3.8_env\\idf_version.txt'
C:\ESP-IDF\-tools\tools\xtensa-esp-elf-gdb\12.1_20231023\xtensa-esp-elf-gdb\bin
C:\ESP-IDF\-tools\tools\riscv32-esp-elf-gdb\12.1_20231023\riscv32-esp-elf-gdb\bin
C:\ESP-IDF\-tools\tools\xtensa-esp32-elf\esp-12.2.0_20230208\xtensa-esp32-elf\bin
C:\ESP-IDF\-tools\tools\xtensa-esp32s2-elf\esp-12.2.0_20230208\xtensa-esp32s2-elf\bin
C:\ESP-IDF\-tools\tools\xtensa-esp32s3-elf\esp-12.2.0_20230208\xtensa-esp32s3-elf\bin
C:\ESP-IDF\-tools\tools\riscv32-esp-elf\esp-12.2.0_20230208\riscv32-esp-elf\bin
C:\ESP-IDF\-tools\tools\esp32ulp-elf\2.35_20220830\esp32ulp-elf\bin
C:\ESP-IDF\-tools\tools\cmake\3.24.0\bin
C:\ESP-IDF\-tools\tools\openocd-esp32\v0.12.0-esp32-20240318\openocd-esp32\bin
C:\ESP-IDF\-tools\tools\ninja\1.10.2\
C:\ESP-IDF\-tools\tools\idf-exe\1.0.3\
C:\ESP-IDF\-tools\tools\ccache\4.8\ccache-4.8-windows-x86_64
C:\ESP-IDF\-tools\tools\dfu-util\0.11\dfu-util-0.11-win64
C:\ESP-IDF\tools
ERROR: C:\ESP-IDF\-tools\python_env\idf5.1_py3.8_env\Scripts\python.exe doesn't exist! Please run the install script or "idf_tools.py install-python-env" in order to create it
Cannot import module "click". This usually means that "idf.py" was not spawned within an ESP-IDF shell environment or the python virtual environment used by "idf.py" is corrupted.
Please use idf.py only in an ESP-IDF shell environment. If problem persists, please try to install ESP-IDF tools again as described in the Get Started guide.
Build Failed
Autoclose turned off
FINISHED
I have installed Pyton 3.8, IDF Version 5.1 all under Win11.
Please be so kind and advice.
BR
Dirk
