PIC18F86/87 J72
Posted: Wed Jul 10, 2024 4:56 pm
Hello team
how fast can the PIC18F86/87J72 be recorded?
Have a look at the data. I am currently building a small measuring device and would like to use it there.
Dual-channel 16-/24-bit Analog Front End (AFE) with Delta-Sigma A/D Converters and high-gain PGAs for 90 dB SINAD and -101 dBc THD (to 35th harmonic) performance
12-bit, 12-channel, 100ksps SAR A/D Converter
LCD driver for up to 132 pixels with voltage boost regulator
Hardware Real-Time Clock & Calendar
Charge Time Measurement Unit (CTMU)for temperature sensing and capacitive touch
Two Analog Comparators
Two UARTs
One Master Synchronous Serial Port (MSSP) support SPI™ and I2C™
Four Timers
Two Capture/Compare/PWM (CCP)
Up to 12 MIPS performance
Internal oscillator support 31kHz to 8MHz and 4xPLL
8x8 Single Cycle Hardware Multiply
nanoWatt low power with Run, Idle and Sleep modes
Brown-Out-Reset (BOR)
Low Voltage Detect (LVD)
Operating Voltage Range: 2.0 to 3.6V for Digital and 12-bit ADC; 4.5 to 5.5V for 16-/24-bit Analog Front End (AFE)
with kind regards
Two UARTs
Four Timers
with kind regards
