Page 1 of 2
Compile error for a do nothing program
Posted: Wed Dec 11, 2024 10:33 pm
by Billduck1302
It may be a bug on my part.
The screenshot says "Compile Error".
I have included the V10 program.
Re: Compile error for a do nothing program
Posted: Thu Dec 12, 2024 9:09 am
by Steve-Matrix
I just tried this project and it compiled without error. Although I had to change the target device because Flowcode complained when I loaded it, saying the FCD file was missing or corrupt.
You should try updating your library files and make sure you are using a valid unmodified target device.
If you are still having issues, please post the .c and the .msgtxt files also as these may help determine what has gone wrong for you.
Posted: Thu Dec 12, 2024 9:13 am
Just a pin not connected can be one of the causes of Syntax error
I loaded your project and for me it compiled without any changes or errors.
Perhaps you could run a full database library update, then reload your project and compile again.
Edit: Steve beat me to it, but at least there are two people now saying your project compiles OK
Posted: Thu Dec 12, 2024 6:55 pm
by Billduck1302
A couple of questions.
1. I opened a known good program on an UNO, modified it and d/l it, and got the same error.
So I am thinking that the problem resides either with my computer or the software.
2. How do you update all library files?
3. What model of Laptop are you using? I am thinking of having a dedicated computer for Flowcode.
Posted: Thu Dec 12, 2024 7:19 pm
by Billduck1302
The C code is too large of a file to post . Even for "Hello World"
Posted: Fri Dec 13, 2024 9:50 am
by Steve-Matrix
Billduck1302 wrote: ↑
Sorry. By "post" I meant add then to a reply here as an attachment. You can either drag the file(s) across onto the area you type in or can use the attachment tab.
The C file should not be too large to be attached. The "Mega_LeafBatteryPackTrials.c" file produce when I compile your project is 101 kB and the "Mega_LeafBatteryPackTrials.msg.txt" file is just 8 kB.
If they are still too large, then you could zip them up and add the zip file.
Posted: Fri Dec 13, 2024 9:55 am
by Steve-Matrix
The information in the C and MSG.TXT files should help us determine what the issue is and we'll know more when we can view them.
It's on the menu bar under "Help...Library Updates..."
Flowcode does not need a particularly powerful computer or laptop to run. If it can run Windows 10, then it should run Flowcode fine.
Posted: Fri Dec 13, 2024 10:32 pm
by Billduck1302
The c file is attached.
Posted: Sat Dec 14, 2024 12:28 pm
by Steve-Matrix
Thanks. The syntax errors occur in the gLCD font routines. I don't know why this should happen though. Are your library files up-to-date?
Posted: Sat Dec 14, 2024 5:03 pm
by Billduck1302
The library files are up to date. Thanks.
The only thing I know to do is to d/l FC 10 onto a new computer.
