Component Library Management Improvement
Posted: Mon Apr 21, 2025 3:11 pm
				Hello everyone,
I have a problem where a previously working project is malfunctioning after updating and recompiling the library.
To avoid such problems, I have a suggestion for improving Flowcode.
If someone has already asked for this or has a solution, please link it here.
Sasi
- The project file can save the name and version of the Component Libraries used during the last compilation, as well as the compiler type and version.
 You can check this in the "Updates" window, in a new "Used Version" column.
- If I open an old project and the "Used Version" and "Current Version" values differ for any of the libraries used, a warning window appears.
- It would also be nice if updating the component library did not overwrite the previous library files. (If this could be resolved, when opening an old project, it would open with the library versions originally used.) This way, the Flowcode user could also select library items from previous versions as "Current Version".
Sasi
