Raspberry Pi HDMI output
Posted: Fri Aug 01, 2025 6:23 pm
by RGV250
I have never used the Pi HDMI output so did not know what to expect, I thought I had it set up but when I simulated it nothing happened until the clear command at the end when it finally changed colour. I was a bit confused as I had the change background command right at the start.
As I was taught at college, If all else fails read the instructions so I tried to download the example (pic 1) and all I get is what looks like the page source code (pic 2).
Bob
Re: Raspberry Pi HDMI output
Posted: Fri Aug 01, 2025 6:30 pm
by mnfisher
If you save that as a flowcode file (.fcfx) then open it with FC all should be well...
Posted: Fri Aug 01, 2025 6:51 pm
by RGV250
Thanks, I thought I would have to wait until Monday.
Bob
