Page 1 of 2
Ethernet module
Posted: Fri Aug 01, 2025 11:52 pm
by RGV250
I have tried to modify code which used an Arduino and TCP_IP_W5500 module for a Raspberry Pi. It appeared to get so far IE Initialise and open a socket but did not seem to get a response. After a lot of head scratching I realised it is probably down to the W5500 module. I added the TCP_IP_Pi component and have then drawn a blank. The functions available are totally different, I figure it should be possible but wondered if anyone had any ideas why there are so many functions missing.
The TCP_IP_ENC28J60, TCP_IP_WIZ3100 & TCP_IP_WIZ810MJ1 all seem to have similar functions so why not the RaspberryPi one?
Bob
Re: Ethernet module
Posted: Sat Aug 02, 2025 12:32 am
by RGV250
My poor little brain cell is really getting fried, I looked at the help for the TCP_IP_Pi component and it did not have a lot of functions. I downloaded the example and was really stunned as it had all the same functions as the W5500. The only issue is that this has TCP_Base in the project explorer. Where is this component as I cannot find it anywhere.
Bob
Re: Ethernet module
Posted: Sat Aug 02, 2025 10:20 am
by chipfryer27
Hi Bob
Not really sure what you mean.
Personally I have only used WiFi on the RPi and haven't really used any LAN since the 8266's came along, as I found them to be an exceptionally cheap way to give a PIC or whatever internet capabilities. Thankfully espressif haven't "improved" (ahem) them in many years so they continue to work :)
I seem to have gathered enough Pi's to open my own bakery (for half-baked ideas) so hopefully I can try and assist.
Re: Ethernet module
Posted: Sat Aug 02, 2025 10:38 am
by RGV250
It was late so probably not that well explained, I will try to do better now the brain cell is awake :-)
This is the program I am trying to convert to the Pi, it was written for Arduino and uses W5500 ethernet.
ARP_01.fcfx
(49.67 KiB) Downloaded 183 times
This is some of the functions for the W5500
This is what the TCP_IP_Pi has
I cannot add any more files / screenshots so need to continue with another post
Re: Ethernet module
Posted: Sat Aug 02, 2025 10:42 am
by RGV250
Continued
And this is what is in this example for the TCP_IP_Pi file
FC_Comp_Source_TCPIP_RPI.fcfx
(32.39 KiB) Downloaded 190 times
From what I can see this has all the functions to W5500 has, I could not find this component anywhere.
Hope that explains it a bit better.
Bob
Re: Ethernet module
Posted: Sat Aug 02, 2025 10:58 am
by RGV250
I did consider using an ESP32 but prefer wired in my house, WiFi not always good.
I have just looked at an old program for one of those and that does not have the same network functions as the W5500 either so would be in the same position.
Bob
Re: Ethernet module
Posted: Sat Aug 02, 2025 12:58 pm
by RGV250
I looked at the help for TCP_Base and it appears that is for simulation only no no use anyway.
Bob
Re: Ethernet module
Posted: Sat Aug 02, 2025 1:11 pm
by chipfryer27
Hi Bob
Just guessing here that as the RPi has an on board LAN, then the FC component may be using inherent code that isn't exposed, whereas for the LAN component it is needed.
Of course that could be entirely wrong.. :)
Re: Ethernet module
Posted: Sat Aug 02, 2025 1:33 pm
by RGV250
I think you are right, the thing I need to figure out is how to use the Pi functions to do the same or I will need a total rewrite which is probably beyond me.
For example, W5500 has CreateMACSocket, CreateTCPSocket & CreateUDPSocket. The TCP_Pi only has SocketOpen and parameters for either UDP or TCP. Nothing for MAC so that does not seem possible.
Then there is SendMyIP & SendMyMAC, I an not sure if I can get away with Send and then the 4 bytes.
Way too many problems I think, not enough drinking time to figure it all out.
Bob
Re: Ethernet module
Posted: Sat Aug 02, 2025 1:37 pm
by LeighM
Yes, you are correct :D the Raspberry Pi TCP component interfaces with the (Linux) operating system API,
which is not the same as the drivers for the likes of the W5500 which expose the lower level code to the user.
