Creation of bootloader for remote firmware updates via UART
Posted: Fri Aug 08, 2025 12:56 pm
by george_b
Hello all!
I wish you have a great summer so far!
I would like to implement remote firmware update on a PIC (16F & 18F) target devices.
After a few minutes of reading, I learned that I will need a bootloader burned in to the flash of my device.
Then this bootloader will handle the image which will be send serially via UART hardware pins.
First i will try to achieve firmware upload to the desired target device with a UART to USB serial connector.
Then I will move on a wireless serial communication device like HC-12 module and try to achieve the same firmware upload wirelessly.
The devices i am interested to use are 18F4680,18F46k80,18F4523.
Is there any instruction or application manual for creating the bootloader?
What else am I missing to achieve my goal?
Thank you in advance
Best Regards
George
Re: Creation of bootloader for remote firmware updates via UART
Posted: Fri Aug 08, 2025 1:09 pm
by mnfisher
Take a look at https://ww1.microchip.com/downloads/en/ ... 00851b.pdf
A Microchip bootloader for MCUs that allow self-programming....
Posted: Mon Sep 01, 2025 5:53 pm
by george_b
Thanks for the details.
I am wondering if i could use flowcode to write a bootloader for pic 18F devices?
Posted: Tue Sep 02, 2025 3:09 pm
by mnfisher
It wouldn't be easy. In theory, Flowcode is C, could be used - some chips have only 512bytes available for the bootloader which might be tight?
If you have a chip that allows more space to be allocated to the bootloader then chances improve.
You will need to do lots of low level register handling and this will be C (or asm) - a Google showed up some possibly helpful code...
Posted: Thu Sep 25, 2025 11:47 am
by george_b
Hi, I hope you are all well!
Since creating this topic, I have been reading online articles and application notes to learn more. To be honest, I don’t feel fully ready to develop my own bootloader at this point. However, I am working on a project that requires continued progress, and therefore, I am seeking an expert who can assist me with this task.
Currently, I have a Flowcode program running properly on an 18F46 K 80 device. The device uses UART to communicate remotely with a server.
My goal is to enable the device to receive a new firmware remotely via UART communication.
If anyone has the expertise to handle this task, I would be glad to discuss the details and be happy to compensate accordingly.
Thank you very much in advance!
George
Posted: Fri Sep 26, 2025 10:05 am
by mnfisher
Have PMd you about this...
